Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 12-31-2016, 05:55 PM   #1
Kemp16V
New member from Pennsylvania
Hi everybody
I have been reading this forum for a couple of years and finally decided to join. I have learned a lot about these trucks from this site. It is amazing how much some of the members know about these trucks. It is definitely one of the best websites that I have come across. I hope to be a member for a long time.
Kemp16V is offline   Reply With Quote
Old 12-31-2016, 09:58 PM   #2
68c10airstream
68c10airstream's Avatar
Re: New member from Pennsylvania
Welcome and happy New Year!! Post a few pics of what you are working on or thoughts of a project you have in mind!
68c10airstream is offline   Reply With Quote
Old 01-01-2017, 12:54 AM   #3
Kemp16V
I am currently working on a 71 LWB that I inherited from my dad. I am currently trying to decide if i should switch to a LS engine with overdrive transmission or keep the 350 with three speed.
Old 01-02-2017, 10:34 PM   #4
68c10airstream
It will most likely come down to budget and your skill set. After all of these years with ls's out there the mysteries are over with. As a past dealer mechanic i looked at it this way; the fuels will continue to be reformulated and will always work with fuel injection but will be challenging for a carb to work at it's best. I don't think anyone who would go through the work to install fuel injection when done and had driven it would say "i wish i would have kept the carb setup".
I did a junkyard pull 2001 5.3 ls with a 2004 4l65e trans with drive by cable, probably the easiest ls transition. Being you got the truck for free if you end up spending 5-10 grand to do the usual ls, disc brake (if needed) dash cluster mods, fuel pump change and possibly relocate tank to the rear frame, etc, you will have a fantastic running truck that will hold it's value.
If you stick 10 grand in a different used truck what's it worth in 5 years compared to the 71. I bet i know which one you will keep another 10+ years!!
Remember it all just bolts in, it's just metal, and there are worse things to spend your money on than this. The joy you get the first time you drive the ls knowing you did it is priceless. Enjoy the ride!!
