Old 02-05-2017, 08:36 PM   #1
68Utility
Shiftrod bushings
trying to find replacement rubber bushings (or grommets) for the shift rod on my 68 C20 w/ a THM 350 transmission. Classic Industries used to show these for 47-66 models, after a call to them, I was informed that they can no longer get even those. Tried NAPA, my local transmission shop which rebuilt this unit about 20 years ago and every major parts house I could think of. Nada.
Does anyone know of a source, or alternately has anyone figured out how to construct a passable substitute from grommets, copper tubing or whatever?
Mark L
68Utility is offline   Reply With Quote
Old 02-06-2017, 04:21 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Shiftrod bushings
You're looking for the one on the steering column lever?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-10-2017, 03:53 PM   #3
68Utility
BigDav160,
Well I would describe it as the one that goes on the short shaft that sticks into the bell crank on the column inside the engine compartment. That would be the upper one. And I also need the lower one that goes in the linkage right down by the transmission. They are different dimensions, and I noted that the upper one actually had a metal bush bonded to the ID. So that bush had an ID of 3/8" and the OD of the rubber that fit over it was 5/8" where it sits inside the bell crank. The "length" of the metal sleeve is about 5/16" so I'd assume the bell crank is about 1/4" in thickness.
One of the owners of the transmission shop I use said "They never wear out". When I showed him what came out, he agreed that they were shot, but said he had no idea where to get replacements.
Mark L"68Utility"
