03-14-2017, 06:17 PM | #1 |
Shock advice for 1969 with 2.5" Drop Spindles
I few years back I changed from drum to disc brakes with a 2.5" drop spindles. I probably should have changed shocks then but didn't have the extra cash...I do know.
I like the look of my ride. Its a tad bit lower in the front than back because of the drop spindles. I want to keep that look or maybe even back the back even with the front. I am worried if I don't get the right shocks it will mess with the ride height. As of now my shocks are absolutely shot and it bottoms out if I am not careful Any advice? I did a little research and what I found that sounds like it might work are the Bell Tech nitro2 drop shocks. I could swing springs if I had to. Any help is much appreciated!
The stupidty of your actions is directly proportionate to the number of people watching you... Last edited by Jayman931; 03-14-2017 at 06:25 PM. |
03-14-2017, 08:43 PM | #2 |
Diggin The SquareLife
Re: Shock advice for 1969 with 2.5" Drop Spindles
get belltech shocks an lower the rear an don't raise the front to level it
03-15-2017, 07:13 AM | #3 |
I am running the belltech street performance shocks and like the ride. Shocks will not change the ride height. Put a set of 3" springs in the back to level the truck some and call it good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-17-2017, 02:09 PM | #4 |
Sounds like a plan. I am ordering these today! Thanks for the info.
The stupidty of your actions is directly proportionate to the number of people watching you... |
03-24-2017, 04:55 PM | #5 |
Belltech Street Performers and the rear 3" Springs came in. As well as alum. radiator, fuel pressure reg and a few small things. Looking forward to a smooth install and a smooth ride
