Old 05-17-2017, 07:24 PM   #1
Slik66
Slik66's Avatar
Passenger rear cab hit hard, patch panel?
This 66 c10 has been smashed in on the passenger rear cab area mainly around the striker plate area. The door is very hard to close/open because the cab area is in by a half inch or so.....and that's after the last guy tried to hammer and pull it out.
I found all this after taking it to the sandblaster.
Is there an available full rear corner patch panel or would I need a donor truck for the part?
It's what you learn After you know it all that counts!
Slik66 is offline   Reply With Quote
Old 05-17-2017, 08:18 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Passenger rear cab hit hard, patch panel?
Donor!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-17-2017, 08:36 PM   #3
hotrodder
If you know or have a porta-power jack the inner striker could be jacked out. No doubt it needs a cab corner, so with the old one removed it would make the push easier, or you can use a come-a-long and pull it out. I would rather repair the OEM one as replace it. Just the ideas of a old bodyman. I am sure others will disagree.
hotrodder is offline   Reply With Quote
Old 05-17-2017, 08:55 PM   #4
Slik66
Slik66's Avatar
I don't have a close up picture but it's pretty bad. It's been drilled and they tried to beat it out before. When that didn't work they just filled it up with bondo.
I knew there were issues when I bought it but sandblasting will let you see ALL the problems, lol
Old 05-17-2017, 09:46 PM   #5
Clyde65
Clyde65's Avatar
I bet you could find a parts cab or...a donor cab to use instead.
I know this guy has a lot of parts, might have a cab. I am close so could look at whatever you might need.
https://dallas.craigslist.org/ftw/pts/6125695844.html
Clyde65
Rebuild of Clyde
support our troops!
Old 05-17-2017, 11:15 PM   #6
franken
Cmon. Get https://www.google.com/search?q=meta...utf-8&oe=utf-8 and go to work.
franken is offline   Reply With Quote
Old 05-18-2017, 12:23 AM   #7
Captainfab
60-66 Nut
Yes you will need to find a donor cab for that entire cab corner. What's all over the cab and frame? Is that the results of having them sandblasted?
Old 05-18-2017, 04:52 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I would recommend what others here have recommended.
If you have room for a donor cab, you might find more on it that can be used or someone else might need. That's what happened with me when I bought a donor cab. I cut the whole roof off and saved it. Saved a section of the dash, and a couple other patch pieces I sold to members here. Back then my forum subscription allowed me to post in the classifieds section of the forum.
So, if you have the space and time, a donor cab would be the way to go.
Or, you might find a local cab at a wrecking yard that might sell you just that section off a junk cab. I did that several years ago on my 66. Beavercreek Auto Wrecking had an old beat up cab that they let me cut a patch section out of.
Ultimately, you were asking if that piece is available to purchase new, but I don't think it is, and would probably be pretty expensive.
66 C20 Service Truck:
Old 05-18-2017, 05:02 PM   #9
LostMy65
LostMy65's Avatar
In fact, new it would most likely be two pieces.
The inside latch section and the outside panel section.
Old 05-18-2017, 08:54 PM   #10
chevylookin
http://www.ebay.com/itm/1960-1961-19...tY4Zi6&vxp=mtr
chevylookin is offline   Reply With Quote
Old 05-18-2017, 09:57 PM   #11
LostMy65
LostMy65's Avatar
Originally Posted by chevylookin View Post
Nice find. However, I think the 60, and 61 are a little different at the door latch section.
Old 05-19-2017, 12:27 AM   #12
Captainfab
60-66 Nut
That jamb is for a '64-'66. The '60-'63's are different. The most noticeable is the 'wedge' below the latch area.
Old 05-19-2017, 11:49 AM   #13
Slik66
Slik66's Avatar
Its a mess... The sandblaster sprayed a metal prep all over it to keep it from rusting.
And I have no idea how I will ever get the sand out of this thing.
Old 05-19-2017, 11:58 AM   #14
timmytimm3
Find an old mattress and get some help to keep rolling it on different sides. Shop vac the hell out of it as you keep turning. You can also use a spray nozzle and air compressor.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 05-19-2017, 12:15 PM   #15
Slik66
Slik66's Avatar
Haven't rolled it around but I've spent probably 3 hours with a vacuum and a rubber mallet tapping on it as I go.
Old 05-20-2017, 12:11 AM   #16
Captainfab
60-66 Nut
Compressed air is the best to try and get the remaining sand out. You will likely be finding sand for some time, but it is a fair price to pay for having all the rust removed as well as any filler so that you can see exactly what you have to work with. Once you get an engine in it and running, the vibration will shake some more sand out of it.
You might want to find out exactly what metal prep the sandblaster used. Reason being, you will want to check and see if it is compatible with the primer you plan to spray over it. Some primers will lift even if silica sand was used. The best thing to do after steel has been sand blasted is to simply epoxy prime it ASAP.
Old 05-22-2017, 02:42 AM   #17
Paul Y
Had the same problem.
Have a look at how I did it. Not saying it is correct but at least it might help.
http://67-72chevytrucks.com/vboard/s...=658621&page=5
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
