Old 06-10-2017, 01:13 AM   #1
SchreinerM
Autometer speedo & tach, adapter required?
Hi everyone, I'm having a bit of trouble finding solid information on using an Autometer speedometer and tachometer with an LS swap (2002 LQ4).
If I want to use this combination gauge:
https://www.amazon.com/Auto-Meter-14.../dp/B001GFS2XK
Can I simply run the ECU output wires directly to the gauge or will I need the adapter shown below?
http://www.autometer.com/ls-plug-pla...h-adapter.html
Thanks,
Matt
SchreinerM is offline   Reply With Quote
Old 06-10-2017, 03:30 AM   #2
a.c.ward
Re: Autometer speedo & tach, adapter required?
I have not used that particular gauge in the LS installs we have done at the shop. I have used auto meters on the LS swaps before. Simply used the instructions provided by PSI for adding a resistor for the tachometer to read correctly, setting the speed and tachometer according to the instructions included in the harness manufacture, and good to go.
worse case, try it that way as see first, and then spend the money for the adapter.
happy motoring
AC
A C Ward Retired US Army
66 El Camino
67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475
a.c.ward is offline   Reply With Quote
Old 06-10-2017, 06:58 AM   #3
dec010974
dec010974's Avatar
yeah, SchreinerM, i would try what a.c.ward has suggested. ive done several swaps and i dont remember needing an adapter for the speedo or tachometer. the PCM will send a tach and speed signal. The speed signal will be calibrated by the electronic speed gauge unless you are using a non electronic transmission. good luck.
dec010974 is offline   Reply With Quote
Old 06-13-2017, 10:37 AM   #4
LS short box
I'm using Auto Meter Sort Comp which internally should be similar. Signal from the ECU to the tach. Same for the speedo. If your style gauge is like the Sport Comp you have select the 4 cylinder mode to get it to read correctly. On the back of the gauge there is a plug. You open that up and you can see inside the gauge and there are three (?) little dip switches. The gauge instruction sheet will illustrate the positions of the dip switches for 4 cylinder mode.
You will like speedo calibration. Just follow the instructions and it works great.
LS short box is offline   Reply With Quote
Old 06-13-2017, 02:31 PM   #5
davepl
davepl's Avatar
I wound up using a Dakota Digital converter box which worked great for me (PM me if you like I can dig up the part number).
But the pull-down resistor, in combination with setting the ECU to 8 cyl tach mode, should work "for free", though I've not done it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
