09-26-2017, 07:03 PM | #1 |
72 c10 flip kit/drop springs
I just installed a DJM flipkit - c notch -new rear springs on the rear and 2 1/2 drop spindles and 2"Big Block lowering springs. I currently have 245/60/15 on front and 275/60/15 on rear my plans are to put a set of 20's on it but would like to get it to sit alittle more level first. Thinking I might have to install a taller front spring any other ideas??
09-26-2017, 07:36 PM | #2 |
Re: 72 c10 flip kit/drop springs
Can you add a 2" block to the rear?
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
09-26-2017, 08:18 PM | #3 |
Petroleum User
Lower in the rear, but I like the rake too. Any more info on springs, pics?
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
09-26-2017, 09:22 PM | #4 |
ECE has a 1 1/2" lowering shackle for the rear.
09-26-2017, 10:55 PM | #5 |
The front are big block 2" lowering springs with 2 1/2 drop spindles purchased from earlyclassic the rear are new stock leafs with overload removed and DJM flip kit. Thinking I may order wheels and tires and make height adjustments after that.
