09-27-2017, 09:39 PM | #1 |
need help please
1. going to install a factory front sway bar in a 1970 c/10 truck that never had one, do I have to remove the 2 bottom rivets in the front cross member ...........
2. also I have to replace the entire radio antenna how do I go about this........ thanks for the help bob
I BELIEVE IN JOHN 3:16 |
09-28-2017, 12:38 PM | #2 |
Re: need help please
Bob, yes you have to drill/grind the two rivets on the front crossmember. As far as the antenna goes, you will have to remove or at least loosen the cowl panel enough to get your arm/hand under there to hold onto/retrieve the aluminum part that keeps the base from turning. See this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=694682
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
09-28-2017, 01:03 PM | #3 |
thanks a bunch................ GOT THE 2 RIVETS OUT........ JUCK WHAT A JOB AND BAR IS FINALLY ON
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-28-2017 at 09:17 PM. |
