Old 09-29-2017, 03:18 PM   #1
mattowar
mattowar's Avatar
Exclamation Chevy Performance Musclecar Oil Pan Kit 19212593 Question
I wanted to know if anyone is using this oil pan on an LS, specifically, LS3, how much lower than the crossmember this pan hangs if at all?
mattowar is offline   Reply With Quote
Old 09-29-2017, 10:02 PM   #2
Steve Cole
Re: Chevy Performance Musclecar Oil Pan Kit 19212593 Question
I can tell you that pan is only about .75" shorter than the truck pan is so it will hang below the crossmember a little. Unless your truck is slammed you should be ok but if you want it above the crossmember, you should look at the F body pan or the CTS-V pan. Check out the LS swap section, more info there.
Steve Cole is offline   Reply With Quote
