Old 10-30-2017, 12:11 PM   #1
LDO
LDO's Avatar
Carb Rebuild Vac. Lines Help
I am finally going to remove my quadrajet carb and rebuild. In the meantime, I would like to clean up some of the vacuum line spaghetti that may no longer be necessary.
Most of this stuff fell apart in my hand from being so brittle but regardless, I have taken some pictures and would appreciate help in identifying what these are, what they do and if it is safe to remove.
Truck is an 85 with a 305 and 700R4. Had a smog pump and tubes into the manifolds but those are all gone.
There is no emissions requirement where I live.
I would like to keep the cruise and the vapor canister.
some of this stuff is attached to the thermostat housing...why??
Pics as promised...
Last pic is of the carb before removal.
LDO is offline   Reply With Quote
Old 10-30-2017, 02:53 PM   #2
LDO
LDO's Avatar
Re: Emissions I.D. Help
Sorry, fixed the pictures...
Old 11-01-2017, 08:21 AM   #3
LDO
LDO's Avatar
Anyone???
Is this thing on???
Old 11-01-2017, 10:01 AM   #4
Dead Parrot
Emissions to keep IMO:
PCV - keeps blowby crap out of your oil and the air
THERMAC - helps with warm up and preventing carb icing.
Vapor Canister - captures gas fumes from tank for later burning.
Much of the rest was an ad-hock pre computer pre injection pre catalyst kluge that often traded performance and/or efficiency to limit HC and NOx, with mixed results.
The reason so much is hooked to the thermostat housing is so it could either be turned on or off when the motor warmed up, depending on the gizmo in question.
Dead Parrot is offline   Reply With Quote
Old 11-02-2017, 05:13 AM   #5
northern 85
northern 85's Avatar
I might have a chilton book ,i will let you know this week end
northern 85 is offline   Reply With Quote
