Old 11-01-2017, 10:49 PM   #1
68longhorn
68longhorn's Avatar
Air Vents
My 86 swb has AC and no vents in the kick panels. Can the kick panel trims be changed to make the vents functional or are they not there on my cab?
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 11-02-2017, 04:48 AM   #2
TKCR
TKCR's Avatar
Re: Air Vents
There are no air vents down there for the AC
Old 11-02-2017, 12:05 PM   #3
Cowdogpete
Re: Air Vents
Actually, there is one on the passenger side. You can swap out the trim and fabricate a 'pull' to open and close it. It is vacuum actuated when you have A/C, but can be changed to manual with a little custom work.
I wish they would have included those in all trucks, A/C or not!
1976 K20, 292 Straight 6, Turbo 400
1984 K20, 350, SM465
1986 C20, 350, Turbo 400
Cowdogpete is offline   Reply With Quote
Old 11-02-2017, 01:38 PM   #4
Jeepwm69
Re: Air Vents
Pics of said vent? Not sure what you're talking about.
Jeepwm69 is offline   Reply With Quote
Old 11-02-2017, 01:58 PM   #5
Mattchu60
Re: Air Vents
I believe they are discussing the fresh air vent that's built into the wall on the passenger side kickpanel, not the vents that heat/air come through.
Mattchu60 is offline   Reply With Quote
Old 11-02-2017, 02:24 PM   #6
Cowdogpete
Re: Air Vents
I don't have pics. But;
If you look just below the glovebox on a squarebody truck, there is a half dome shaped plastic trim piece, attached to the upper portion of the kickpanel and colored like your door panels. Behind that is a vacuum actuated air vent. When you put your A/C control on "Vent" it routes air from the cowl, through this vent into your A/C ducts.
This can be bypassed and made into a manual vent if you no longer have A/C or choose to get rid of it for whatever reason. Lets more air in than you might think.
Non-A/C trucks have them on both sides from the factory.
Old 11-02-2017, 03:05 PM   #7
Desert_Eagle02
Re: Air Vents
Can't believe I'm saying this, but I'm glad my truck doesn't have A/C. I love my kick panel vents! One day I may add vintage air, but the vents are staying!
This actually explains why my buddies truck doesn't have them. We couldn't figure out why it didn't. Too bad too since the previous owner took off all the A/C stuff under the hood.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 11-02-2017, 06:35 PM   #8
TKCR
TKCR's Avatar
Re: Air Vents
Yeah the fresh air vent
Old 11-02-2017, 06:52 PM   #9
TKCR
TKCR's Avatar
Re: Air Vents
It's the right side kick panel. Here's a pic, top left in the photo. The kick panel with the opening.
Old 11-03-2017, 09:03 AM   #10
xrcr
Re: Air Vents
I actually cut the opening out on the drivers side on an AC cab and put the old style "floor" vent in. It was a little tedious but it was worth it. there was actually a stamped area there for a template.
xrcr is offline   Reply With Quote
Old 11-03-2017, 12:09 PM   #11
Jeepwm69
Re: Air Vents
Gotcha. My truck has A/C which, of course, doesn't work. I've wondered what was under the little dome, but haven't ever looked.
I've got to tear into my entire system. The temp lever only goes about 2/3 of the way to cold before it stops, and my airflow doesn't seem to switch to the proper vents when I switch from vent to heat to defrost.
Old 11-03-2017, 09:41 PM   #12
68longhorn
68longhorn's Avatar
Re: Air Vents
Yep fresh air vent is what I meant. Thanks guys
Old 11-03-2017, 09:45 PM   #13
Matt Man
Matt Man's Avatar
Re: Air Vents
When I put vintage air in my non AC cab 81, I kept the fresh air vents and it is very nice to have them. Crack the window a tad, open the floor vent and you get nice air flow.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
