Old 12-21-2017, 04:33 AM   #1
jr1966
Question Caliper and Spindle ???
Ran into another problem on lowering my 69 GMC. I ordered CPP 2 1/2 inch Drop spindles and when I went to install I noticed the Calipers mounting bolt holes seemed to look different.
The bolt holes on the spindle now on the truck were 5 3/4 inches center to center and the new spindle mount holes were 7 inches apart. No fit on these ? I called CPP and they said it looked like according to the measurement that I had S10 spindles and Calipers. The Tie Rod hole is not the same size and no fit also on new Cpp spindles. Did not check Ball Joint fitment.
Anyone heard of this before and best way to resolve.
Get S10 spindles or start all over. Front suspension was supposed to be from 82 model. 1 1/4 rotors fit both spindles OK.
Thanks for any ideas
JR
jr1966 is offline   Reply With Quote
Old 12-21-2017, 07:47 AM   #2
PGSigns
PGSigns's Avatar
Re: Caliper and Spindle ???
Post pictures of what you have and we may be able to better identify them for you.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-21-2017, 09:02 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
JR
What spindle part number do you have?
Keith
Convert to disc brakes.
Old 12-21-2017, 10:18 AM   #4
jr1966
The ones on the truck now have 15649948RH CFD7 17 GM and 15649947LH CF010 GM
I can't find if these are part numbers or casting numbers. I tried to look up on Google but no luck converting them.
Old 12-21-2017, 10:52 AM   #5
lolife99
lolife99's Avatar
I meant the CPP spindle part number,...
Keith
Old 12-21-2017, 12:41 PM   #6
jr1966
i meant the cpp spindle part number,...
cp4s4s
Old 12-21-2017, 01:00 PM   #7
lolife99
lolife99's Avatar
cp4s4s
That is the correct part number for 73-87 spindles.
Posting pics would definitely help.
Keith
Old 12-21-2017, 03:16 PM   #8
jr1966
test attch
Old 12-21-2017, 03:17 PM   #9
jr1966
This is the on on there now. Not the CPP spindle
Old 12-24-2017, 01:33 AM   #10
jr1966
Question Re: Caliper and Spindle ???
JR
Well it looks like the front suspension is 72 not 82 as the guy said I got it from. It has the hex head A arm bushings. Still need to find out about the spindle bolt hole measurement Are these S10 spindles on it now and I need S10 drop spindles or do I need to start all over and put the CPP spindles and then change caliper,ball joints and tie rod ends?
Thanks JR
Old 12-24-2017, 09:43 AM   #11
lolife99
lolife99's Avatar
S10 spindles are
totally different.
Change your upper ball joint and outer tie rod to the 71-72 version.
The lower ball joint should fit.
Did you check the lower ball joint for fit?
Keith
Old 12-24-2017, 07:09 PM   #12
jr1966
S10 spindles are
totally different.
Well looks like I am going to remove the spindles on it now and try to use the CP4S4 which are 73 up ones I already purchased . I will have to get new brake calipers to fit them Can you tell me which ball joints and tie rod ends I will need to finally get it together? In other words will I need 73 up parts instead of the 72 stuff on it now?
Thanks a bunch for the info - JR, doing this job for my son, I am getting too old 74 to lay under these things
Old 12-24-2017, 07:46 PM   #13
lolife99
lolife99's Avatar
You need 73-87 ball joints and outer tie rods.
1-1/4” rotors and calipers.
Keith
Old 12-24-2017, 07:53 PM   #14
lolife99
lolife99's Avatar
I’m pretty sure the spindles on your truck now are 92-98 c1500 spindles.
NOT S10 spindles.
There’s a lot of people that shouldn’t be working on these trucks.
Here’s a 92-98 drop spindle.
Same caliper mount.
Keith
Old 12-24-2017, 11:06 PM   #15
leddzepp
Moderator
leddzepp's Avatar
Those are 88-98 spindles. Someone swapped them to do a six lug disc brake conversion on your 69. It was commonly done years ago, and there is an faq here on it. You have a c20 lower control arm as such, and that will complicate any other 1/2 ton spindle you try to swap in as those arms will not accommodate the c10 ball joint.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-24-2017, 11:12 PM   #16
leddzepp
Moderator
leddzepp's Avatar
IF you want to hit the easy button, just buy 88-98 c1500 dropped spindles, as they will bolt right up to what you have already and return all other parts you bought.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-25-2017, 10:59 AM   #17
lolife99
lolife99's Avatar
Hasn’t it been proven on this board that there’s are camber issues with the 88-98 spindle swap?
Maybe its just with drop spindles, but I still don’t recommend it.
Keith
Old 12-25-2017, 11:03 AM   #18
lolife99
lolife99's Avatar
Http://67-72chevytrucks.com/vboard/s...d.php?t=620262
Keith
Old 12-25-2017, 09:51 PM   #19
leddzepp
Moderator
leddzepp's Avatar
Thanks for posting that. Just goes to show you can’t believe everything you read on the internet. I found two replies in the FAQ where they said it worked, but I’ve never seen any pics posted. I picked up a set of 4” fabtech lift spindles from a 92 in the junkyard and was planning on using them, based on the FAQ I read here on the board. After reading the above linked thread I feel like it will be a waste of time and money to continue that project.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
