Old 02-19-2018, 08:20 PM   #1
cfan10
cfan10's Avatar
Cool TBI Issues
'90 suburban 350 TBI (low miles)/700r4
OK, so I changed the fuel pump last week, oil pressure switch again, coil, fuel filter, recent tune up, tank full of gas, ordered new connectors for the wires to the pump.
I have a haynes book for 88-98 which seems to cover only the ck series and not the old square bodies even though they were made until '91.
Before it would only start and run for a minute if I sprayed starter fluid into the throttle body. If I wanted to start it again, repeat the process.
I didn't hear the pump turn on before I changed it, still not turning on.
I removed the fuel filter and connected the line to a hose, tried to start it and it filled the container.
Looking at the injectors no fuel is getting to them, even with spraying it doesn't start.
Not sure if this is related but I tried to start it today and the key was stuck in the ignition in on position basically trying to start, had to run and pull the battery cables to turn it off. Now I try to hook the battery up and it sparks really bad.
I'm trying to ensure everything works fine because I'm going to switch over to a '91 suburban because this one the frame shock mount is broken.
The '91 donor has no wiring harness or engine/transmission.
As always any advice is greatly appreciated!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 02-19-2018, 08:30 PM   #2
cfan10
cfan10's Avatar
Cool Re: TBI Issues
The burned connector goes from the harness on the firewall to the tank, the yellow wire connected to the fuel pump relay goes to the positive battery terminal.
Old 02-19-2018, 10:26 PM   #3
hatzie
Moderator
hatzie's Avatar
Re: TBI Issues
The burned connector in the picture is a Delphi Weatherpak 2 position #12059473
You'll need the Delphi 12089040 Male terminals and Delphi 15324982 Green seals because that overheated fuel pump terminal is likely pretty brittle now.
You probably need the Delphi Weatherpak 12015792 2 position tower as well along with the 12089188 female terminals along with the same green seals as the male half.
Remove that yellow bodge wire before you have a fire. It looks like you almost had a catastrophe with that fuel pump connector next to the gas tank.
Repair the insulation on the White and Orange wires with adhesive heatshrink. Don't cut the wires. If you cut the wires the repair will not be as sturdy as the original wire will be without a splice. You'll probably have to extract the terminals on those wires from the fuel pump relay socket to slide the shrink over the exposed strands without cutting them.
Find out why the ECM B fuse isn't supplying power to the Orange wire with the ignition turned on.
The only service manuals that really cover the RV trucks are the GM manuals. Haynes takes a whack at it in the 73-87 manual but...
The 1991 Emissions and Driveability manual has a troubleshooting and diagnosis sections with troubleshooting trees for no-start condition and various fuel delivery system troubleshooting trees and pages of written diagnostics.
This GM manual covers the full line of light trucks so you'll want to take care to read the sections that apply to your RV series rig.
Troubleshooting the fuel pump system starts on page 3-12 PDF page 56.
The No-Start troubleshooting tree A3 is on page 3-31 PDF page 75.
The fuel pump relay circuit troubleshooting starts on page 3-40 PDF page 85.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-20-2018, 08:38 AM   #4
cfan10
cfan10's Avatar
Cool Re: TBI Issues
You are truly a fountain of knowledge, sincere thanks for time in helping me!!!
