Old 03-30-2018, 08:07 AM   #1
hevymetl
Power steering
Quick question. Along with capnfabs brackets, can I use the power steering set up, including gear box, out of a 6cyl '70 Nova for my '66 c10 2wd long bed? Have a line on complete set up. I plan on this being the summer of the 66 finally!
Thanks, John
hevymetl is offline   Reply With Quote
Old 03-30-2018, 08:18 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Power steering
You mean like the steering box?
Old 03-30-2018, 08:49 AM   #3
hevymetl
Re: Power steering
Yes. Trying to figure out a price for everything and just wondering if I should grab steering box along with the pump, bracket, hoses, pullies.
Old 03-30-2018, 09:01 AM   #4
The Rocknrod
Moderator
Re: Power steering
Looks like the 70 Nova box is mounted on the "inside" of the frame, where the 72 C-10 Box is mounted to the outside. So no.
Old 03-30-2018, 06:00 PM   #5
ray_mcavoy
Re: Power steering
I agree ... the Nova steering boxes (along with many other GM car steering boxes) mount to the inside of the frame as opposed to the truck boxes that mount outside.
Assuming your C10 has an inline-6 (like the Nova), you should be able to use the power steering pump, pulleys, and pump mounting brackets though.
ray_mcavoy is offline   Reply With Quote
Old 03-30-2018, 06:22 PM   #6
hevymetl
Re: Power steering
Yup. 6 cyl. I was at work earlier and couldn't do the research as far as what steering box fit and what wouldn't. I appreciate the quick help in a pinch. I think I have all the other stuff sewed up for $200. It's on the car and operable which is great so I can see it work. Just have to get there and remove it.
Old 03-31-2018, 01:03 AM   #7
Captainfab
60-66 Nut
Re: Power steering
You need a steering box and pitman arm from a '68-'86 C series truck, Suburban or 2wd K5 Blazer or a '87-'91 R series truck, Suburban or 2wd K5 Blazer.
Old 03-31-2018, 07:31 PM   #8
hevymetl
Re: Power steering
Thanks cap. I'm going tomorrow am to grab the pump, brackets, etc. He has a 84 c10 there with a 350 in it as well. Maybe I can get the steering box off that. I'll look when I'm there. When you get a chance, pm me the payment info for one of your steering box brackets for a 66 c10. Thanks.
Old 03-31-2018, 11:30 PM   #9
Captainfab
60-66 Nut
Re: Power steering
PM sent.
