Old 09-30-2018, 02:18 PM   #1
MySons68C20
MySons68C20's Avatar
Wind Wing Rubber Question
I'm rebuilding the wind wings on the 68 and ran into a problem with the rubber fitment.
The driver side tucks firmly into the channel and the pass side is quite a bit looser.
I've triple checked and both sides look good I'm just afraid the pass side won't stay put.
Is it normal practice to not have to use weatherstrip adhesive on these?
I'm tempted to run a small bead of adhesive on the loose side.
What do you think?
MySons68C20 is offline   Reply With Quote
Old 09-30-2018, 03:16 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wind Wing Rubber Question
Vent window gaskets/seals are not created equal.....
Read this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
The vent window gasket comparison begins with post #29.
LockDoc
Leon
Old 10-01-2018, 03:08 PM   #3
MySons68C20
Thank you LockDoc, I appreciate your prompt help and informative posts!
I went ahead and ordered from CP and will update once I give them a try.
Blake
