Old 12-03-2018, 05:36 PM   #1
Afirehawk1
66 c10 Tire & Wheel Combo with 2.5/4 drop
Need some advice
Working on this truck with 2.5 inch drop spindles and 4inch rear drop springs.
Want to run 20 inch rims
Trying to determine best tire size spec
Any experience out there?
Can not afford trail and error on this project
Keith
Afirehawk1 is offline   Reply With Quote
Old 12-05-2018, 05:48 PM   #2
Afirehawk1
Re: 66 c10 Tire & Wheel Combo with 2.5/4 drop
anyone?
Old 12-05-2018, 06:16 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Have you done your backspace measurements yet?
http://www.thewheelsmith.net/images/...0spec-form.pdf
Old 12-05-2018, 07:20 PM   #4
Afirehawk1
Yes
Front back top bottom
I just dont know what to do with all these numbers
Old 12-06-2018, 11:36 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
Almost all tire makers post the specifications of their tires by size (tread width, section width, circumference, diameter, approved rim width, load, speed rating, etc.). Use your measurements to determine the wheel dimensions you want, and then select tire size that will fit your application.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-06-2018, 11:47 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I use this tire calculator to help figure out what tire size I want and it will show me what tires area available in that size. Also gives you some sizes up and down from what you put in, to help compare.
https://tiresize.com/calculator/
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-06-2018, 12:00 PM   #7
Afirehawk1
trying to mimic this look. this truck has a 3.5/5 drop with 275/40/20 in the front and 275/45/20 in the rear.
i understand having the 2.5/4 setup, the truck will sit up in the air 1 inch higher.
thoughts on the tire or wheel adjustments that i need to make.? can i reduce the tire diameter slightly to get the same look?
