Old 12-03-2018, 06:53 PM   #1
montana92
17 spline to 30 spline swap
im working on a 63 c10, rear end is a 12 bolt from what i can tell. lady brokke the spider gears an welp they dont make 17 spline gear set for the trucks anymore. so i was thinking if i ordered a 30 spline spider gear kit, an found some 30 spline 30.5" 6 lug shafts then thats all i would need to do the swap correct??
montana92 is offline   Reply With Quote
Old 12-03-2018, 07:53 PM   #2
montana92
Re: 17 spline to 30 spline swap
i just want to make sure i order the right parts, i was looking at ordering these shafts MG27133 an the typical yukon 30 spline spider gear kit.. any help would be much help
Old 12-04-2018, 01:00 AM   #3
Captainfab
60-66 Nut
If you purchase parts for a '65 to early '70 truck 12 bolt, they will work. In fact as for the spider gears, the truck 12 bolt was used thru 1982.
Old 12-04-2018, 02:25 PM   #4
montana92
so I could use these axle shafts TEN Factory MG27133 an use the Yukon or what ever 12 bolt truck spider gear set correct?? I don't need to swap axle bearings ect???
Old 12-04-2018, 02:29 PM   #5
montana92
https://www.ebay.com/itm/SPIDER-GEAR...-ge:rk:11:pf:0 the set I was looking at
Old 12-05-2018, 12:39 AM   #6
Captainfab
60-66 Nut
Yes those spider gears should work. There is a possibility that the axle bearings and seals may need to be changed since those used in the '63 are a bit of an oddball. Just check the fitment with the new axles.
