Old 12-13-2018, 05:11 PM   #1
montana92
12 bolt spider gear problem
Rebuilding this 12bolt. New spider gears. Problem is gears won't fit with the shims/thrust washers, seems they lock the gears up.. now if I remove all 4 then she goes together an spins like it should no problem.. talked to a old timer an he said it would be fine to run with out said shims if there ain't any MAJOR LOOSENESS AN from what I can see there is very very little move me to. (trucks just a cruiser stock 230ci an 3 on the tree. Is he correct?? I can't seem to get a right AWNSER from anybody. Had this problem in a old d30 for a wheeler an ran it with out an never had a problem..
montana92 is offline   Reply With Quote
Old 12-14-2018, 12:50 AM   #2
Captainfab
60-66 Nut
Re: 12 bolt spider gear problem
I have run a 12 bolt without the shims/thrust washers with no issues. But then again that truck did not get a lot of miles put on it.
Old 12-14-2018, 01:13 AM   #3
montana92
The spider gears seem a little loose, (haven't measured yet) but installed 1 thrust washer on the 1 smaller gears an it tightened every thing up REAL tight. Have to use the axle shaftan some force to rotate it... Should I run it like that or remove said washer an run it loose???
Old 12-14-2018, 11:14 PM   #4
Captainfab
60-66 Nut
It is hard to say not being able to put hands on it, but it has been my experience with most things it is better to run it a little on the loose side rather than tight. When things are too tight, that is when heat builds up and things start to eat each other.
Old 12-15-2018, 08:03 AM   #5
red211
Originally Posted by captainfab View Post
it is hard to say not being able to put hands on it, but it has been my experience with most things it is better to run it a little on the loose side rather than tight. When things are too tight, that is when heat builds up and things start to eat each other.
x2
red211 is offline   Reply With Quote
Old 12-15-2018, 02:55 PM   #6
jdl71
jdl71's Avatar
x3
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
