Old 12-13-2018, 06:19 PM   #1
Hogger54
Hogger54's Avatar
63 GMC windshield install help needed.
I have the rubber seal installed, and ready to rope it in, but need to know how much to rope in each side as I go.
I'll be starting in the center on the bottom. Should I pull the seal on with the rope ends a little at a time, going from side to side, working it on evenly?
Or should I just start on one side, and work it all the way around?
Hogger54 is offline   Reply With Quote
Old 12-13-2018, 06:58 PM   #2
68JOHNDEERE
Re: 63 GMC windshield install help needed.
Rope in about a foot each way from the bottom center, then help seat that area of the gasket into the truck. Then rope out past each bottom corner about 8 inches and seat those areas (that will center the glass into the opening). Then work both sides up around the top corners, and seat those then do the rest of the top a half at a time. Be sure the gasket gets seated fully into the cab as the gasket will have a secondary lip that will hang up on the pinch weld.
I used this video as a reference: https://youtu.be/zA8sX1KR6J0
68JOHNDEERE is offline   Reply With Quote
Old 12-13-2018, 07:25 PM   #3
Hogger54
Hogger54's Avatar
Awesome, thank you.
