Old 01-23-2019, 03:12 PM   #1
CanadianK20
CanadianK20's Avatar
Any pictures of where/how this is mounted?
I’m pretty sure it’s the kickdown switch for the th400. The 400, intake manifold and engine in my truck is not the factory setup so I’m trying to figure out how to make this work. Thanks
CanadianK20 is offline   Reply With Quote
Old 01-23-2019, 03:24 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Any pictures of where/how this is mounted?
I think ive see those on the gas pedal too
1967custom
michael bustamante is offline   Reply With Quote
Old 01-23-2019, 03:59 PM   #3
sick472
sick472's Avatar
I've seem several kickdown swithces at the gas pedal inside the truck cab as well, but that one looks like it belongs mounted close to the carb which is also a common place for them to be installed.
The photo shows a similarly looking setup from a 65 impala which came from the linked thread that has other, but not so similar, setups...
https://classicoldsmobile.com/forums...wn-switch.html
Simply put, mount it so that it activates under near full or full throttle off the carb (or gas pedal). If your intake is different, you may have to customize the bracket. Just don't mount it such that it restricts full throttle (unless a teanage boy is involved and then mount it so that it won't spin the tires and leave it unplugged - LOL).
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
