Old 08-21-2019, 09:54 PM   #1
BigBird05
Adding factory gauges to a 1972 C-10
I am changing over from a standard light instrument panel to the factory gauges, no tack. I have repined the connector but I have an empty spot, # 12. This is for the volt gauge. The diagram that I am useing calls for a Black / brown wire, but it doesn't tell me where in comes from.( the other end ) I need this information to finish rewiring my truck. Thanks
BigBird05 is offline   Reply With Quote
Old 08-22-2019, 12:02 AM   #2
John H.
John H.'s Avatar
Re: Adding factory gauges to a 1972 C-10
Welcome, your going to need a wiring diagram which you can search here or GMC Paul’s website. 1. Did you change your front light harness? You need to do that with a gauge one. There are two fuse links that need fuses. My reproduction one did not have the fuses in them. You have to change the pin locations on the fuse block side too? Just go slow and follow the GMC Paul’s website.
John H. is offline   Reply With Quote
Old 08-22-2019, 04:46 AM   #3
BigBird05
I am reworking the old Front Lamp harness.These 2 fuse that mentioned, do they go to the voltage gauge in the cluster? I have a factory manual and it does not have the gauge schematic in it.
Old 08-22-2019, 05:59 AM   #4
GMCPaul
You'll find the instructions for doing this about 1/2 way down the following page link
https://gmcpauls.com/TechTips1.htm
In those you'll see the 2 fuses are added to each of the 2 wires you need to add to forward lamp harness for amp gauge. So those fuses are in the engine compartment.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 08-22-2019, 11:46 AM   #5
BigBird05
That's what I needed to know. Thanks
Old 08-23-2019, 01:03 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
You will find that the number 1 and number 12 spots on the connector are for the amp gauge. You will need to add the wiring to the engine compartment and make sure you run the two 4 amp fuses as in the wiring diagram.
If it helps, I offer a volt gauge conversion for these trucks that eliminates the amp gauge and all of the wiring for it, including the above mentioned fuses.
Let me know if you have issues with wiring, I can help if needed.
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
