09-08-2019, 08:12 PM | #1 |
Stepside Taillight Isuues
I have searched and can’t find the answer I’m looking for. I wanted to switch to these lights for my taillights. They light up great when I apply my brakes but barely burn when I turn on the turn signal. Any ideas ?
Posted via Mobile Device |
09-08-2019, 09:21 PM | #2 |
Old member
Re: Stepside Taillight Isuues
2 wires coming out of it means:
1 wire is brakes and turn signals the other is running lights. You have to ground it to the truck frame either by a bracket are a ground wire to the mount. The same wire for brakes is for turn signals also.
09-08-2019, 09:26 PM | #3 |
X2 on the grounding that Andy said.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
09-08-2019, 09:42 PM | #4 |
Thanks. That fixed my problem.
09-08-2019, 10:03 PM | #5 |
Old member
Good deal!
