Old 10-25-2019, 07:23 PM   #1
Tuff Gong
Tuff Gong's Avatar
Cleaning out gas tank question.
Whats the best way to clean the old gunk out of your gas tank without removing it. The tank is fine just need to flush it clean. Any thoughts?
Tuff Gong is offline   Reply With Quote
Old 10-25-2019, 08:43 PM   #2
72blu
72blu's Avatar
Re: Cleaning out gas tank question.
No real way to flush it with the tank in the cab. Take it out and get it properly flushed/coated.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges
1972 SWB Custom 10, gauges, cammed LQ9, M22
72blu is offline   Reply With Quote
Old 10-25-2019, 08:57 PM   #3
Redneck Rydes
Redneck Rydes's Avatar
Has to come out,When I did mine I put in so,e 3/4 crush clean gravel and sloshed it around,and then some small chain,cleaned up pretty good.
Redneck Rydes is offline   Reply With Quote
Old 10-25-2019, 10:26 PM   #4
Astro-Balls
Astro-Balls's Avatar
Will Radiator shops flush out tanks?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-25-2019, 10:33 PM   #5
Tuff Gong
Tuff Gong's Avatar
I think they will. I’m trying to avoid pulling the tank all the way out because it’s not that bad
Old 10-25-2019, 11:41 PM   #6
dagnabbitt
dagnabbitt's Avatar
Most will, or they should. I'm lucky to have one in my town that will do it, I'd check around. Some places will also put a coating inside too. Generally you end up spending more or less the same as you would on a new tank.
Thats not always a good value proposition for some folks, but for me, I'd rather spend it on an old tank I know fits and is OEM than some new piece of junk.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-25-2019, 11:47 PM   #7
Tuff Gong
Tuff Gong's Avatar
I think I’m just going to drain the gas change the filter and call it good. I know it’s probably not the right thing to do but I’m sure at a work
Old 10-26-2019, 09:36 AM   #8
Dan-K
Been down that road , save yourself the headaches and buy a new tank.
Dan-K is offline   Reply With Quote
Old 10-26-2019, 10:10 AM   #9
Tuff Gong
Tuff Gong's Avatar
What kind of problems were you having because of the bad tank you had
Old 10-26-2019, 10:23 AM   #10
Dan-K
The truck had sat for twenty plus years . I took the tank out filled it with gravel and vinegar and shook it , then flushed it several times and re-installed it . I put a large filter between the tank and the fuel pump and another after the pump before the carb and also the one inside the carb (Rochester). What I did filtered out the large particles but I kept getting small rust particles through all the filters that eventually clogged up the carb internally . So after my experiences I would say pony up and buy a new tank .
Old 10-26-2019, 01:04 PM   #11
Tuff Gong
Tuff Gong's Avatar
So I got the tank out. Now I just need to decide if I’m going to buy a new one or clean this one out. It doesn’t look terrible but it’s hard to get a good look inside
Old 10-26-2019, 01:37 PM   #12
Getter-Done
Getter-Done's Avatar
I tried using a rusty - dirty tank once.
This was years ago.
After that experience I would replace it.
By the time you buy 10 fuel filters you will have the tank paid for.
One more thought do you want to carry a spare filter with you
and not know at any moment you may have to change it (Rain or shine )
(Hot or Cold) .
IMO it will give you peace of mind.
84 Chevy K-20
Old 10-26-2019, 03:37 PM   #13
Tuff Gong
Tuff Gong's Avatar
Overall the tank is in decent shape but suspect. The sediment that came out was yellow, then milky white. I beat on the bottom of the tank with a rubber mallet and you could see flakes floating out as I flushed it. The radiator shop quoted me $160 to clean back to bare metal. I ended up just buying a new aftermarket tank.
Old 10-26-2019, 04:42 PM   #14
vitamin_c95
Best I can say is, call for quotes. I called two local shops. They quoted me $255 and $250 for a flush and seal. Eff that. I can drive an hour to brothers or classic industries and get a new tank cheaper. I even tried to.flush it myself but it's a PITA to get the water out. So I'm going to get me a new tank
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 10-26-2019, 05:06 PM   #15
Tuff Gong
Tuff Gong's Avatar
I already snag a new tank and will install it this weekend. Hopefully the swap out is as easy as the removal. After hearing all the comments sender like the safest way to go.
Old 10-26-2019, 05:58 PM   #16
Tuff Gong
Tuff Gong's Avatar
So my new gas tank doesn’t have any vent line provisions. Do you not need them anymore
Old 10-26-2019, 06:03 PM   #17
burb71
Active Member
I would say avoid doing it if you really don't have to, unless you use oil or gas as the liquid with a chain to do the scouring.
I used soap and water, bad idea!!!
There is sort of a baffle with the fuel necking, and you can't get all of the water out it starts to flash rust and you can have a bigger problem than you started out with.
burb71 is offline   Reply With Quote
Old 10-26-2019, 06:46 PM   #18
Tuff Gong
Tuff Gong's Avatar
Here is my original tank with venting and new tank without. So weird.
Old 10-26-2019, 07:52 PM   #19
AussieinNC
Moderator
AussieinNC's Avatar
What year model is the truck?
There are two tank styles, vented and non vented....
Does the truck fuel pump have a return line back to tank?
Is there a breather system passenger side door pillar?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-26-2019, 08:03 PM   #20
Tuff Gong
Tuff Gong's Avatar
My truck is a 70.
Old 10-26-2019, 08:14 PM   #21
AussieinNC
Moderator
AussieinNC's Avatar
Should be a vented tank....but I dont think the original tank is actually the correct one....
The EEC vent pipe is usually on the filler tube, not in the body of the tank itself...
Would you mind posting the brand and part number of the "new" tank...thanks
2012 Chevy Equinox
Old 10-26-2019, 08:14 PM   #22
Redneck Rydes
Make sure you use a new vented gas cap
Old 10-26-2019, 08:17 PM   #23
randy500
You would be better off with a tank cleaning at $160 than mess around with that crappy repro tank....
randy500 is offline   Reply With Quote
Old 10-26-2019, 09:12 PM   #24
Tuff Gong
Tuff Gong's Avatar
Agreed. I'm taking back the tank I bought and getting the original one cleaned. Its going to set me back a few days but it will be the best fit.
Old 10-26-2019, 09:15 PM   #25
Tuff Gong
Tuff Gong's Avatar
All the hard venting lines are there so I think my tank is stock. I will post specs on the new tank if it is on the box.
