Old 10-31-2019, 02:56 PM   #1
54blackhornet
54blackhornet's Avatar
QJet Prime Issue ?
I had the original QJet on my 71 GMC rebuilt twice by two different shops. I run non ethanol gas always. If the truck sits for any length of time it will not start unless you pump the gas pedal, last count 16 times. The well plugs where resealed both times. Looking for ideas on how to correct...thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 10-31-2019, 03:47 PM   #2
weim55
Re: QJet Prime Issue ?
Are you certain the choke is functioning properly and adjusted correctly?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 10-31-2019, 04:44 PM   #3
HO455
Post Whore
HO455's Avatar
I would let it sit and then I would remove the top of the carburetor to see where the fuel level is before trying to start it. If it is up where it should be then it's likely your accelerator pump has failed. With the second choice being the check valve not working correctly.
If the fuel bowl is empty or very low then it is likely one or more of the well plugs is leaking.
RIP Bob Parks.
Old 10-31-2019, 04:48 PM   #4
JMac11
JMac11's Avatar
Correct fuel filter installed correctly in the fuel fitting also a good thing to check
JMac11 is offline   Reply With Quote
Old 10-31-2019, 04:52 PM   #5
54blackhornet
Thanks guys ! Can you see fuel by looking inside the throat ? I didn’t think it would start if the accelerator pump was not functioning. Running a in-line filter and the one inside the fuel inlet....appreciate the help
71 C-20
07 Magnum RT AWD
Old 10-31-2019, 06:23 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Two things come to mind:
Fuel pump check valves are leaking allowing fuel to drain back to tank when shut off
You do have the thick insulating gasket between the carb and manifold ?....if not, the fuel will boil away after shut down
I usually run an electric fuel pump on my own trucks...wired thru a shut off switch that hidden away...helps deter the "midnight spares" crowd....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-31-2019, 06:34 PM   #7
truckster
truckster's Avatar
Based on your observation, I would strongly suspect an issue with the choke rather than a lack of fuel in the bowl. If you're pumping the gas and it starts, that indicates there's fuel. If it only starts after it cranks a while, that indicates a lack of fuel.
When it's cold, take the air cleaner off, and without cranking it, depress the accelerator pedal and release it. The choke plate should snap closed and the throttle should be on the high idle cam. If that's not the case, your choke is either bad, disconnected, or incorrectly adjusted.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-31-2019, 07:05 PM   #8
100%Chevy
A big part of your problem is probably evaporation.
If mine sits for more than week,I have to prime the float bowl.
Takes about 5 ounces in the top vent hole.
Same problem with my Edlebrockes.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-31-2019, 07:07 PM   #9
El Dorado Jim
I run an edelbrock carb on my truck, have the same issue, i put an inline electric fuel pump on a switch, I use it for a minute or so when my truck has been sitting for a week or more, gets gas to the carb quick, then im not cranking forever until gas gets there from the mechanical pump
El Dorado Jim is offline   Reply With Quote
Old 11-01-2019, 11:14 AM   #10
54blackhornet
Thanks fellas ! The truck will only start after pumping the pedal numerous times, even if it sits overnight. I will check the choke, it’s divorced type...Jack
71 C-20
07 Magnum RT AWD
Old 11-01-2019, 11:27 AM   #11
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Accelerator pump check ball not sealing. I had the same problem then I bough "Cliff Rugles " quadrajet book. I learned a lot and how to fix it. Use a old check ball and tap a few times with a punch. It forms a new seat. What a difference it made.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-01-2019, 11:40 AM   #12
54blackhornet
Thanks OldBlue for your help.
71 C-20
07 Magnum RT AWD
Old 11-01-2019, 03:01 PM   #13
HO455
Post Whore
HO455's Avatar
You can not see the fuel level in the float bowl from the outside on a Qjet. You however can see how well the accelerator pump is working by looking down the primary bores and winging the throttle open. You should get two good solid streams shooting across the bores. Weak streams in conjunction with a choke plate that is not fully closed before the engine starts can cause the symptoms you are experiencing.
If the pump seal lip has failed or as Old Blue K and I have said the check valve is leaking you will have a poor accelerator pump shot. So if the pump shot is poor the first step is to see if you have fuel in the float bowl and that means pulling the top off of the carburetor without spilling fuel out of the carburetor. I usually just do this with the carburetor still bolted on the intake manifold.
If you have enough fuel in the float bowl then it is highly likely the pump lip seal or the check valve is the culprit.
RIP Bob Parks.
Old 11-01-2019, 03:06 PM   #14
HO455
Post Whore
HO455's Avatar
A Qjet won't drain back through the fuel pump as the needle and seat are not on the bottom of the float bowl.
RIP Bob Parks.
Old 11-01-2019, 11:59 PM   #15
rsgt
rsgt's Avatar
I had cliff Ruggles build my Quadrajet. If it sits for 3 or 4 days it has to crank quite a bit. 1 or 2 days and it starts right up.
rsgt is offline   Reply With Quote
Old 11-02-2019, 12:19 AM   #16
randy500
Your problem is probably evaporation but it could be leaking back through the fuel pump if you have a windowed seat in your quadrajet.
It could be a leak where the seat screws into the bowl.
You can vacuum test the needle and seat by applying vacuum to a test fitting at the carb inlet.
You can also vacuum test the fuel pump at the inlet, should hold vacuum.
Parts changing possible drain back cures to be used with or without vacuum testing
1. Remove clip on needle which seals the seat regardless of float position.
2. Install fuel filter with built in check valve.
3. Install non windowed seat.
randy500 is offline   Reply With Quote
Old 11-02-2019, 04:13 AM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
^^^This!^^^
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
