11-02-2019, 04:05 PM | #1 |
68 C-20 PCV hose
I have been searching for a PCV Valve and hose for my 68 C-20. Can't seem to find one anywhere. The one I have is dried and cracked and I am sure causing me a vacuum leak.
Anyone know where I can get one or a compatible one? Thanks
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
11-02-2019, 04:33 PM | #2 |
Re: 68 C-20 PCV hose
I'm sure mine is just 3/8 fuel line. Air cleaner or carb hose?
11-02-2019, 04:44 PM | #3 |
Go to O’Reilly’s and say you need PCV hose. They sell actual proper PCV hose there instead of fuel lines. It comes in 24” lengths. I was lucky enough that I only needed 12”, so I have a replacement hose for next time!
1968 GMC C2500 Long Bed Fleetside |
11-02-2019, 04:45 PM | #4 |
PCV hose is different than fuel lines. It’s made to withstand the oil particles that will get in there.
11-02-2019, 04:48 PM | #5 |
It seems to be harder than just plain hose and it has a shape. I'll get a picture.
I am trying to keep this truck looking as original as possible
11-02-2019, 04:52 PM | #6 |
It’s probably just hard because it’s old. PCV hose is an easy off the shelf item. It’s your truck, but for me I don’t care so much about hoses and other wear items because you replace them every few years anyways. The one I bought is just black with maybe some really light type on it, but at the back of the engine bay you can’t tell. If it’s a show truck then that’s a different issue!
11-02-2019, 04:59 PM | #7 |
I do see some of the bent hoses on Amazon but says it won't fit my truck. I'll stop in Napa or O'Rielly's and see what I can find. Thanks for the input. Nice to be driving it at least and didn't get stuck!
11-02-2019, 05:02 PM | #8 |
11-02-2019, 05:08 PM | #9 |
This is the one from Amazon, I wonder if it's really the same thing!
https://www.amazon.com/Dorman-46039C...QAWZV2EY2V7VCN
11-02-2019, 05:18 PM | #10 |
Moderator
Why not try your local auto parts store and ask if they carry the Dorman part number....
If they have it you can see if it will fit .... Just be aware their price will be 50% or more higher than Amazon....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-02-2019, 05:57 PM | #11 |
When you get your pcv done there’s an important job for you.
Get rid of that glass type fuel filter. It’s a huge fire waiting to happen! |
11-02-2019, 08:50 PM | #12 | |
Who Changed This?
When my factory molded hose went bad, I simply bent up a piece of 3/8" steel brake line and put short nipples at the ends. As much stuff as was butchered on this truck, I'm not worried about that small bit of non-original parts.
11-02-2019, 09:02 PM | #13 |
Old member
You could always go with this one in your truck!
DF-17 Dual Flow PCV Valve Features patented Dual Flow technology (US Pat. No. 9,376,945). $129.00 Adaptor Required? http://mewagner.com/?p=444
11-03-2019, 08:50 AM | #14 | |
You need a 90 degree style like in here. https://en.wikipedia.org/wiki/Crankc...ilation_system |
11-03-2019, 09:18 AM | #15 |
Check here and see if he has any left:
http://67-72chevytrucks.com/vboard/s...d.php?t=679341
72 C10 lwb fleetside -stock 350/350 combo |
11-03-2019, 05:43 PM | #16 |
Nothing fancy under this hood. I've used the elbow on the PCV on half a dozen of my GM rides. Never a problem.
11-03-2019, 08:10 PM | #17 |
For what it's worth, here's a picture of the hose and valve on the original engine from my '69 C20. Look's just like the OP's. The hose is also original. I replaced the valve in the early '70s with an identical straight valve. I tossed the valve I took off in my toolbox and it's still there!
Anybody want a picture or part number of the original valve? |
11-03-2019, 08:38 PM | #18 |
Well dang!
Wrong again for the second time this year! My apologies for the mistake. |
11-03-2019, 09:52 PM | #19 |
11-03-2019, 10:00 PM | #20 |
This style works.
https://www.amazon.com/Fuel-Filter-L.../dp/B01CFKS9IC Parts store has them. A carb shop epoxied you’re fuel line! You might need to fix that too. Take a pic of it. There are parts available to do it right. |
11-03-2019, 10:12 PM | #21 |
No, they epoxied the the large nut that holds the filter. The fitting to the fuel line screws into the large nut. It was stripped when I got the truck,
Posted via Mobile Device My neighbor is a machinist. Later, he will put a heliicoil in for me and I will replace the hardline but I need the in-line for now |
11-03-2019, 10:17 PM | #22 |
Who Changed This?
You can get a metal can-like filter. It's what I use on mine, though it does have a decent nut on the carburetor. My FiL installed the inline filter due to getting lots of crud in the auxiliary fuel tanks.
11-03-2019, 10:19 PM | #23 |
That’s bad.
There are replacement fittings available. It’s possible your original carb might not be fixable if it starts to leak. Best to be gentle with it. Fittings found here. https://quadrajetparts.com/quadrajet...-c-128_27.html |
11-03-2019, 10:25 PM | #24 |
Thank you all! Information is much appreciated
11-03-2019, 10:53 PM | #25 |
