02-10-2020, 05:12 PM | #1 |
Before and After
Steering column lower bearing sits outside of housing.
Hey All,
I rebuilt my column a while ago, and just now replaced it into the truck. I am noticing that the spring doesn't offer enough pressure to keep the bearing into the steering column. I am positive that the rebuild is accurate (didn't miss anything). I do not have the steering wheel installed at this time as I am still working on the interior and it is a lot easier to maneuver without it in place. Is this normal when the steering wheel is not in place yet? Picture #1 I can move the isolator up to get it to push the bearing into place. Picture #2 Pictures are uploaded upside down for some reason.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
02-10-2020, 06:26 PM | #2 | |
The Older Generation
Re: Steering column lower bearing sits outside of housing.
Yes, you have to have the steering wheel in place. You will have to have a second person push up on the intermediate shaft (isolator) so the bearing is up in the tube to be able to put the steering wheel on. LockDoc
02-10-2020, 07:05 PM | #3 |
Before and After
Well, that is a relief.
