03-29-2020, 07:12 PM | #1 |
rear brackets
I was told I need to drill out the spot welds and move these brackets over to be centered on the frame...is this correct?
03-29-2020, 08:32 PM | #2 |
Re: rear brackets
a better description or some pics a little further away would help us know what it is you are talking about.
03-29-2020, 08:46 PM | #3 |
Re: rear brackets
its the rear of the bed
03-30-2020, 02:08 PM | #4 |
Re: rear brackets
if you are putting it on a S10 frame you do (I did).............but I don't know what you are working on????
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
03-30-2020, 10:11 PM | #5 |
Re: rear brackets
its a 56 truck and the frame is from a 55 truck I believe. Its the rear panel across the back of the bed. I think the brackets are suppose to be mounted over the frame
03-31-2020, 12:30 AM | #6 |
Post Whore
Re: rear brackets
mounting brackets over frame rails
03-31-2020, 11:43 AM | #7 |
Re: rear brackets
ok thats what I thought just wanted to make sure
03-31-2020, 10:27 PM | #8 |
Re: rear brackets
if you don't already have a copy, here is a pdf. it should tell you all the little assembly details for a stock truck. worth keeping a copy on your computer or a memory stick.
https://www.trifive.com/55-59Assy.pdf |
04-01-2020, 12:27 AM | #9 | |
Post Whore
Re: rear brackets
04-01-2020, 12:12 PM | #10 |
Re: rear brackets
thanks for all the great replies
04-01-2020, 05:41 PM | #11 |
Re: rear brackets
I have the exact same issue. I am told that my box is from a '64 ?? truck where the frame rails are wider than my '57.
My tabs or mounting flanges are messed up worse than yours. I was going to buy a new rear piece, but I may remove and relocate. thanks for posting |
