01-31-2021, 05:39 PM | #1 |
Steering shaft connection help
So can I use the stock steering shaft and connect it to aftermarket column. The stock shaft end has a round end with a pin in it. Thanks
01-31-2021, 06:17 PM | #2 |
Re: Steering shaft connection help
Yes , You should have bought it from Pickmup his come with the billet u joint , Made in the USA
http://67-72chevytrucks.com/vboard/s...d.php?t=522483
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 01-31-2021 at 06:24 PM. |
02-01-2021, 10:05 AM | #3 |
So does that cap with the pin in it come off the shaft or is it part of the shaft?
02-01-2021, 10:45 AM | #4 |
You have to cut the shaft and use a billet U joint , Read the thread .
http://67-72chevytrucks.com/vboard/s...=522483&page=6
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-01-2021, 11:13 AM | #5 | |
