Old 06-23-2021, 11:28 AM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
mirror mount
So the pevious owner mounted the mirrors in the wrong location. They block the vent windows from completely opening. Was kind of hoping to find a style mirror that I could mount in the same location but would clear the window. Tying to avoid more holes in the door. Even if I had to to drill holes it would be nice If I could find some mirrors that the base would cover the old holes. Any suggestions would be appreciated.
Lethal Tendencies is offline   Reply With Quote
Old 06-23-2021, 12:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: mirror mount
I don't think you will find any mirror that will cover the holes because the mirror is mounted in the wrong location. Not only does it need to be moved back but it should be mounted lower, on the flat area. This is an old thread but it shows the correct mounting location.
https://67-72chevytrucks.com/vboard/...d.php?t=179279
LockDoc
Leon
Old 06-23-2021, 08:37 PM   #3
Peanut74
Re: mirror mount
Thanks for the info LockDoc. I am getting close to mounting my mirrors and you saved me a bunch of research time. By the way my drivers door had at least four different mounted on it. Spent a lot of time filling in holes.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 06-23-2021, 09:15 PM   #4
LockDoc
LockDoc's Avatar
Re: mirror mount
No problem. They can be a pain sometimes....
My '68 has a few extra holes I will need to take care of.
LockDoc
Leon
