Old 10-24-2021, 11:00 PM   #1
TxCajun
TxCajun's Avatar
Side Molding Mounting Holes
1. Is the area around the Side Molding Mounting Hole supposed to follow the body contour? That is, flat or curved with the body depending on where the hole is located?
2. If these have been "dimpled" by some overly aggressive person with a ball peen hammer, any suggestions on how to rework them?
Background:
I’m stripping the bed on my truck for paint, and someone in the past has filled the Side Molding Mounting Holes with body filler. It also appears to me that they “dimpled” these mounting holes in to the body before filling them with in order to make the filler stick to the hole.
My truck cab did not originally have Side Molding although one of the fenders and one of the doors had Side Molding holes which have been weld filled (kind of a Frankenstein of body parts). In the end, I think I want to purchase and install Side Molding, so I'm trying to determine the best path forward to repair these areas on the bed sides.
Thanks!
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 10-24-2021, 11:19 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Side Molding Mounting Holes
All the factory holes for the trim would have been flush with the rest of the body. The previous owner of my truck had also replaced the bed and filled the trim holes with filler, but he did not dimple them like that
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-25-2021, 09:35 AM   #3
jayoldschool
Moderator
Metal should be flat. Likely dimpled by the guy who put the bondo on so it would have more to hold. Hammer and dolly will have it flat quickly.
jayoldschool is offline   Reply With Quote
Old 10-26-2021, 10:09 AM   #4
TxCajun
TxCajun's Avatar
Then I'm guessing you must have the same extruded Bondo caterpillars along the inside of your bedsides. :-)
Old 10-26-2021, 10:26 AM   #5
cwcarpenter98
I did! I was stupid back then and decided to break off all the worms, thus opening the holes back up. I immediately regretted that decision because it made my truck look weird with trim holes on the bed but no trim or holes anywhere else. Now those bedsides are on my trailer, so I don't care anymore
Christian Carpenter
