Old 03-22-2022, 09:54 AM   #1
Droff
Fuel Tank Fitment
I bought a Dorman in cab fuel tank to replace my old, leaking tank and the new one doesn't quite want to fit right.
It looks like the filler neck needs massaged a little bit to move it closer to the tank and a little to the front as well. Right now, when I slide the neck through the hole in the cab, the tank itself won't sit against the back or bottom of the cab like it should.
Any suggestions on how to 'massage' the filler neck without causing more problems?
Thanks.
'68 GMC 3/4 Ton
350, 700R4
Droff is offline   Reply With Quote
Old 03-22-2022, 10:03 AM   #2
kwmech
Re: Fuel Tank Fitment
Rubber mallet
Old 03-22-2022, 01:59 PM   #3
Accelo
Accelo's Avatar
I believe kwmech is correct. My stock tank had a crinkled snout that I am confident was made to be moved.
Accelo is offline   Reply With Quote
Old 03-22-2022, 02:13 PM   #4
Droff
The rubber mallet crossed my mind, figured I'd put the cap on to try to keep it round on the end before I start massaging.
This tank has a straight neck, not a flexible looking neck like the old one.
Thanks.
'68 GMC 3/4 Ton
350, 700R4
