Old 04-02-2022, 05:01 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Seat bracket help
Cleaning the garage still and forgot these were in there. The measurements are with the adjuster slid all the way back. The single to the right is a little taller and a touch wider on the upper brackets. Looks different than buckets seats. Bench seat i assume?
Thanks for any help
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-03-2022, 08:48 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Seat bracket help
This thread might help a little Eric.
http://67-72chevytrucks.com/vboard/s...d.php?t=510997
I don't have any trucks left to check on.
LockDocc
Leon
Old 04-03-2022, 10:10 AM   #3
too much stuff
Roadtrip!
Thanks leon, they appear to be bucket seat brackets? I will check a set of 73 and up buckets i have and compare.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-03-2022, 10:19 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I’ve never seen bench seat brackets like that.
Definitely bucket seat brackets
But way shorter than the 73+ brackets.
Hard to tell in the pictures.
Keith
Convert to disc brakes.
Old 04-03-2022, 01:43 PM   #5
LockDoc
LockDoc's Avatar
Here are a couple more threads,
http://67-72chevytrucks.com/vboard/s....php?p=5374820
https://67-72chevytrucks.com/vboard/...8855396&nojs=1
LockDoc
Leon
Old 04-04-2022, 07:53 PM   #6
conoco
conoco's Avatar
my bench seat bracket look just like those on my 72 k20. There are only 2 of them, one on each side with a long metal wire connecting the pull handles to engage them to slide back and forth. My truck is original. I just took them out, sand blasted and painted them. I will try to find the picture and post it. They are identical to those though. Good luck.
1972/Sierra Grande k2500 / 383 / th350 with Gear Vendors / 4.11 / 4" lift with 35s / Eaton Rear Axle
conoco is offline   Reply With Quote
Old 04-04-2022, 08:21 PM   #7
too much stuff
Roadtrip!
conoco, please post up pics. Thanks.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-07-2022, 10:56 AM   #8
conoco
conoco's Avatar
I'll be home from the oil fields next week and will get them to you.
