08-31-2022, 10:55 PM | #1 |
Jeep Aluminum Slot Wheels
Hello all, I have purchased a set of what I believe to be Jeep aluminum slots. 15x7, 6 lug. I plan on putting them on my 67 C10. My question is on the type of lug nut these wheels require. From what I gather and from the looks of the lug nut seating area they take a regular 60 degree lug nut. Anyone able to confirm that? Thanks.
08-31-2022, 11:30 PM | #2 |
Re: Jeep Aluminum Slot Wheels
Post a pic.
09-01-2022, 06:59 AM | #3 |
Ok, I'll see if I can figure that out. Might have to enlist my better more computer savvy half to assist me.
09-01-2022, 09:38 PM | #4 |
Some pics.
09-01-2022, 10:37 PM | #5 |
Looks like the normal acorn type is used, but is the hub bore big enough?
09-02-2022, 03:33 AM | #6 |
Would check backspacing. Newer wheels will be HPO (high positive offset) The wheels may inset quite a bit.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-02-2022, 07:05 AM | #7 |
I believe these wheels are about mid to late 70's vintage. The backspace is not ideal but I believe they will work. I mounted one tire and mocked it up, the tire moved in about 1/2 in. I searched a bit and have seen where folks are running these wheels on C10's.
09-02-2022, 07:30 AM | #8 |
those would need the tapered lug nuts
wheels that use the shouldered nuts don't have that large countersink
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-02-2022, 07:54 PM | #9 |
09-02-2022, 09:30 PM | #10 |
Nice find. I like the old school slotted mags.
09-03-2022, 01:40 PM | #11 |
09-03-2022, 02:08 PM | #12 |
I drilled and tapped the wheels and used rally wheel center caps. I had a clearance issue with the brake drums. I ended up taking a die grinder to the wheels.
09-04-2022, 12:41 PM | #13 |
I have slots on my Jeep. Love them!
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
09-04-2022, 12:45 PM | #14 |
One better. These aluminum alloys from American Wheel in my 71.
09-04-2022, 12:49 PM | #15 |
Complete truck.
09-04-2022, 01:00 PM | #16 |
My 79 back in the day with the same wheels.
