Old 01-03-2004, 08:02 PM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Question Quick instrumentation illumination questions
First, are the bulbs in the instrument cluster wired in series or parallel? In other words, if one bulb burns out, does it take out one entire side of the dash?
Second, are the heater and A/C controls on a 67-72 (factory A/C) supposed to be illuminated? If so, are they the same 194 bulbs or are they different? Where are they located?
Thanks!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-03-2004, 08:25 PM   #2
rage'nrat638
rage'nrat638's Avatar
yea the heater controller is lit....one on each end 194 bulbs
i do not think that one bulb out kills the rest....
was not the case on mine....
rage'nrat638 is offline   Reply With Quote
Old 01-03-2004, 08:27 PM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
The gauge panel lights are wired up in a parrallel circuit. If one goes out, it wont effect the rest of them.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-03-2004, 08:31 PM   #4
shuttermutt
Bummer! It appeared that only one bulb was dead on the left-hand side of my dash yet the entire left-hand side was black. It was still too light to see if replacing the 3 bulbs I could find did the trick or not. Now that it's dark, I'll check 'em and see. Guess I'll dig around for those heater control bulbs, too.
'Mutt
Old 01-03-2004, 08:37 PM   #5
724x4a/cchevy
If you look at your heater control, There is a hole right behind where it says defrost,air,heat. Right behind those words there is a hole, or a bulb housing, Try replacing that bulb. That display should light up when you turn your headlights on.
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 01-03-2004, 08:38 PM   #6
724x4a/cchevy
If your truck is a/c ther is a hole on each side of that display!
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 01-03-2004, 09:02 PM   #7
shuttermutt
Yep, it's an A/C truck. I replaced the right-hand (passenger) side bulb, but no love. I've got a couple of loose connectors up there, though. I'll have to troubleshoot when I have daylight. In the mean time, I've got my instrument lights working again. Well, except for the one near the oil pressure gauge. I think I'm missing one of those neat-o bulb holders for that one.
'Mutt
