02-27-2023, 03:59 PM | #1 |
Reverse Light Wiring?
Just Wondering How The Wires Attach To These and Where I Can Get Them?
Thanks Posted via Mobile Device |
02-27-2023, 04:10 PM | #2 |
Re: Reverse Light Wiring?
02-27-2023, 06:29 PM | #3 |
He's a Mopar guy, so there's that.
Kidding On a 71, probably 68-72. Stop & turn plugs into the housings. Reverse are single wire bullet connectors. The rear side marker ground terminal connects to the bed’s interior sheet metal with a (GR 5) 3/8" hex flange tap screw. The screw threads are 1/4" x 1/2", and the heads are stamped “D”. The rear lamp wires are 18 AWG and; • Brown for tail lamps, license plate lamp and markers. • Yellow for LH turn lamp. • Dark green for RH turn lamp. • Light green for reverse lamps.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-27-2023, 06:36 PM | #4 |
and the "these" thing on trans, aka BU light switch, needs to be plugged in
