Old 08-03-2023, 09:15 AM   #1
AlaskaK10
Junior Member
Factory or not Frame Humps
Hi All
I am working on my short wheel base 1966 K10 frame. I have two symetrical humps on the top of each frame rail right where the rails go from straight and start to bend inward toward the front for the engine. It appears to me that when the frame rails were bent inward at the factory the metal humped up both in the same area. I have another frame and from a long bed that does not have thease humps though any thoughts?
AlaskaK10 is offline   Reply With Quote
Old 08-03-2023, 10:00 AM   #2
raidmagic
raidmagic's Avatar
Re: Factory or not Frame Humps
They sure look symmetrical and no corresponding humps on the bottom frame rail. Probably nothing to worry about. Someone with more knowledge than me will chime in though I'm sure. I'll look at my frame tonight and see if it has those or not.
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 08-03-2023, 03:54 PM   #3
AlaskaK10
Junior Member
My long bed frame same vintage does not have them. Maybe a different plant. The measurement data I have found says 54.5 inches from core support center hole to first cab mount center. This measurment checks out so has to be a factory thing.
