08-10-2023, 09:26 PM | #1 |
Door Pressure Relief Valve Retrofit
Have any of you retrofitted one of these pressure relief valves into the door jamb of an older truck? How did it work out? If my fresh air vent isn't open, it's difficult to close the doors, and I like to keep the vents closed when running A/C.
08-10-2023, 09:32 PM | #2 |
Re: Door Pressure Relief Valve Retrofit
I like you're Thinking on this.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
08-10-2023, 10:29 PM | #3 |
I added one on my 69 when I put the a/c in. Worked out fine.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
08-11-2023, 01:20 AM | #4 |
08-11-2023, 09:06 AM | #5 |
I really can't remember. Didn't have any problem with the doors closing both before and after the installation. I'd say go for it. Can't see any negatives
08-11-2023, 10:47 PM | #6 |
That's not Standard for MY '68 AFAIK.
I know 919 doesn't need it, but then there's no door rubber at all. Doesn't last in this heat. Aren't those for letting off vapors from an in-cab fuel tank?
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-12-2023 at 02:17 PM. |
08-11-2023, 10:48 PM | #7 |
08-11-2023, 11:38 PM | #8 |
I have the same problem with my doors. I can feel the blast of air come out when closing from the pressure caused from closing the door. If I crack the window or vent window. Doors shut awesome. I have also been thinking of doing this. Or putting them in the back of the cab between the cab and bed as they are installed on newer trucks
08-12-2023, 01:49 AM | #9 |
I may have an unconventional way of thinking about this. I would rather cut a strip of the rubber off of the pivoting kick panel vent door than have another piece of plastic in the truck. I like as little plastic as possible. Either way the point is to create an air leak.
08-12-2023, 01:53 AM | #10 |
I agree with you about the plastic. I'm also hesitant to cut a gaping hole in my cab. I've just been leaving my fresh air vent slightly open. It does feel like it affects the function of the A/C doing that though.
08-12-2023, 01:57 AM | #11 |
Either method is an air leak and my thought is either method should affect the a/c the same.
08-12-2023, 02:00 AM | #12 |
The door vent has rubber flaps that act like check valves to let air out more easily than in.
08-14-2023, 10:39 PM | #13 |
If you don't like the plastic OEM, there are metal options like this in polished or black:
https://www.summitracing.com/parts/aay-djv-p
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
08-14-2023, 11:22 PM | #14 | |
08-17-2023, 04:31 PM | #15 | |
08-17-2023, 04:45 PM | #16 |
I think most repos have no baffling vents behind it. You have to find ones that specifically say it is there. These state in the add that it is complete as factory. https://www.ebay.com/itm/35245827284...Bk9SR5yoiNTAYg
08-17-2023, 10:19 PM | #17 | |
