10-15-2023, 10:46 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Which tool to remove center of steering wheel?
5 screws to remove the steering wheel. How to remove this thing? Just not sure which tool for this purpose. Thanks again.
And not sure why it's flipped again. 🤔 |
10-15-2023, 10:53 PM | #2 |
Re: Which tool to remove center of steering wheel?
Looks like perhaps an aftermarket steering wheel adapter. If those are threaded holes then I think try a steering wheel puller of the type that does a 3 point pull. You can probably rent one for free from a local auto parts store.
10-15-2023, 11:00 PM | #3 |
20' Daredevil (Ret)
Another option that works well...
10-16-2023, 06:54 PM | #4 |
All about them K’s
If you’ve got a welder and a few tools you can easily and cheaply build your own…
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
10-16-2023, 09:34 PM | #5 |
You have lots of Options.
I will suggest a little penetrating oil. Of your choice. Here is your flip. Ama zon or HF are options. Rent a puller or Buy one on A MoZon or Harber Freight.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
10-16-2023, 10:23 PM | #6 |
How did that threaded shaft turn into a pig snout just because the picture flipped? That's funny.
10-16-2023, 10:30 PM | #7 |
Here you go with no Pig
