Old 01-13-2004, 12:35 AM   #1
71swb4x4
71swb4x4's Avatar
Help me remove my front rotors
Help me remove the rotor from my truck. I have a 1/2 ton 4x4. I have removed the lockout and the snap ring. The sockout that I have that says it will work for my truck won't fit inside. Do I need to remove the aluminum looking thing? I will attach some pics - help me out.
Shawn
The first one is before I removed anything.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-13-2004, 12:42 AM   #2
71swb4x4
71swb4x4's Avatar
Here is with the lockout and clip removed.
Old 01-13-2004, 12:45 AM   #3
71swb4x4
71swb4x4's Avatar
Here is the lockout I removed
Old 01-13-2004, 12:47 AM   #4
71swb4x4
71swb4x4's Avatar
Here is the clip I removed
Old 01-13-2004, 12:49 AM   #5
71swb4x4
71swb4x4's Avatar
Here is the back of the lockout
Old 01-13-2004, 12:51 AM   #6
71swb4x4
71swb4x4's Avatar
Sorry about the large pics - you should have seen them before I shrunk them!! Frist time I have posted pics - next time I will use a smaller resolution. The second pic is the inside of the hub. What else do I remove to get my socket in there? I will post a pic of the socket too.
Old 01-13-2004, 12:57 AM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Yes it has to come out, push it back in a ways and there will be a round ring just inside the outer edge of your hub, use a pick to get under an edge of the ring and pull it out, now slide your hub out and you can get to your spindle nuts.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-13-2004, 01:09 AM   #8
71swb4x4
71swb4x4's Avatar
Thanks for the help Blazerman - I got a little bit further.
I got the aluminum thing off, and the nut off. The rotor still won't come off. I am sure its something easy, any ideas?
Old 01-13-2004, 01:14 AM   #9
BLAZERMAN
BLAZERMAN's Avatar
If you got the first nut off you should have a washer with a bunch of holes all the way around it, its keyed in the groove in your spindle, pull it out and then remove the other spindle nut, it will have a small tit on it that has to line up in one of the holes in the lock washer, this keeps your spindle nuts from backing themselve out.
Old 01-13-2004, 01:27 AM   #10
71swb4x4
71swb4x4's Avatar
Thanks for the help. I shut the garage down for the night. I will give it another shot tomorrow.
Shawn
Old 01-13-2004, 04:06 AM   #11
doughby82
doughby82's Avatar
be careful putting the washer back in the one with the tit on it.it will break pretty easy.mine broke and i didnt relize it untill i heard griding sound coming from the front end.after i took it apart,it was pretty scored in there ,it was in 5 peices
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
