06-05-2024, 02:35 AM | #1 |
Molded Heater Hose Delete. Inlet/Outlet Jumper Hose
Any of you guys jump across the inlet/outlet and delete the water going to the heater core? If so you got a part number?
Oh Yeah, it's a 350.... Thanks! Last edited by Loose Screw; 06-05-2024 at 02:47 AM. |
06-05-2024, 11:31 AM | #2 |
Re: Molded Heater Hose Delete. Inlet/Outlet Jumper Hose
A short piece of hose does the job fine.
71 C-20 07 Magnum RT AWD |
06-05-2024, 11:53 AM | #3 |
Just plug the holes with a fitting. There is already a by pass in the water pump via the hole below the bottom bolt. Just takes a tad longer to purge the air out. Most people jump with a hose b'cuz they can't get the fittings out or are just doing a temporary thing
06-05-2024, 12:08 PM | #4 |
I have a big ole loopty Doo on there right now. I was looking for something more stream lined like this---->
hose.JPG Anybody using this hose? |
06-05-2024, 12:25 PM | #5 | |
port plug.jpg Thanks! |
06-05-2024, 01:11 PM | #6 |
Who's got steelies?
No, you'll need something with a tapered pipe thread.
The threaded holes in the intake & pump where the hose nipples go are 1/2" NPT.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
06-05-2024, 01:32 PM | #7 | |
Fitting.jpg Thanks! |
06-05-2024, 03:15 PM | #8 |
Who's got steelies?
Close.
That's a reducer, it will still have a hole in it. you need something like this: https://www.mcmaster.com/4638K514/
06-05-2024, 07:22 PM | #9 | |
