06-12-2024, 12:40 AM | #1 |
70+ ( Old Skool Club )
Shoulder Belt Question
I have a set of Tim Korineks shoulder belts that I'm gonna put in my truck. That stud/bolt on the pillar how does it come out . Its smooth and looks like cab was painted with it installed so how do I remove it wihout scratching anything.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-12-2024, 01:25 AM | #2 |
Re: Shoulder Belt Question
If your truck never had the shoulder belts that is just a plastic plug in the thread hole. Just pop it out. If painted in place be careful not to chip the paint so much that the belt piece will not cover. running a utility knife around it may help. You will have to source the proper shouldered bolts if they are not included with the belts.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-12-2024, 01:26 AM | #3 |
I believe it's just a plastic plug that you have to pull/pry out
06-12-2024, 02:37 AM | #4 |
Thanks, my truck never had shoulder belts and bolts are included with the seat belt set.
06-12-2024, 05:31 AM | #5 |
Active Member
If it never had shoulder belts, I assume you position the pivot where it’s comfortable, drill a hole then fish those backing plates up between the inner and outer skin of the cab, then bolt them down?
06-12-2024, 11:46 AM | #6 |
A guy from "Seatbelt planet" told me when I asked why their 3 point kits were listed for 68 - 72 and not 67 trucks is because some 67 trucks don't have the captured nut for the shoulder belt from the factory. My 67 GMC has the bolt hole there, maybe because it was the "custom cab" model.
He said as far as he knew all the 68 - 72 and some 67's all have the built in ability to accept the shoulder belt bolt.
I got a bench seat baby, you don't have to sit over there. |
06-12-2024, 12:48 PM | #7 | |
it's just a plastic plug that looks like this once you've gotten it out. Assuming you're interior hasn't been repainted, you should be able to slip a thin piece of twine behind the head, wrap it around and pull it out without damaging the paint on your pillar. If the interior has been repainted, you would need to do as Richard said and carefully use a razor blade to separate the head of the plug from the pillar so you can slip the twine behind it. |
06-12-2024, 03:13 PM | #8 | |
06-12-2024, 03:27 PM | #9 | |
It's my understanding that if a truck has those plastic plugs, there will be a receiving nut behind them. The plugs were there to cover up the hole that would be used for those rare accessory shoulder belts that were available for our trucks at the time. My plugs are the same color as my interior, gold, and my interior has never been repainted. Last edited by cericd; 06-12-2024 at 04:28 PM. Reason: clarification |
06-12-2024, 04:15 PM | #10 |
Couple of ways to get the plug out. On one side of the plug lay down some masking to protect the paint. Then using a thin putty knife just pry it out.
Or along the twine idea go to the bait shop and get some braided fish line (20-30 LB) and try that as its much more thinner than any twine. |
06-12-2024, 04:51 PM | #11 | |
06-12-2024, 05:34 PM | #12 |
I worked the edges a bit then was able to unscrew the plugs from mine.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
06-12-2024, 07:19 PM | #13 |
Ha, the picture of the plugs on top of the chevy stool is mine. I was looking for it to post in this thread. I have about 40 plugs, I collected them many years ago when these trucks where plentiful in the wrecking yards along with a lot of other stuff like 72 only door screws and ferrules, the ones by the wing window. Most of the plugs broke trying to extract them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-12-2024, 08:42 PM | #14 |
At the body shop.
Stabbed it needle nose pliers and turned them out
" That didnt make it any newer " " Dont antique the equipment " |
06-12-2024, 10:23 PM | #15 | |
HA! Well you found it LOL! I've come here to the forum a few times to find pics I posted and lost. My plugs were easily removed with my fingers...they came right out. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-12-2024, 10:40 PM | #16 |
Who Changed This?
I think (in '70) CST came with shoulder harness. The holes were there when I got the truck. FiL pulled the belts. ?
06-12-2024, 10:46 PM | #17 |
I would think that that plug is screwed not pushed in. Or pushed in and threads have a good bite on the plug. I would try to cut any paint at the contact point and then unscrew not pull. I was just in this area for hours fishing a wire today. You have the factory mounts luckily so you get to avoid setting those plates.
06-13-2024, 01:34 AM | #18 |
My '67 K/10 Suburban had that shoulder belt mounting nut. I pulled the one out of the Passenger Side B Pillar and threaded a bolt in, holding a pear ring carabiner. On the Drivers Side rear door arch, there was a similar weld nut intended for a Barn Door pivot. [I have a lift Hatch and Tailgate.] I mounted another bolt holding another pear ring carabiner so I could clip the end rings of a hammock, run diagonally from left rear to right front. It was a replica navy canvas hammock, as in the days of sail. Great when camping.
I let a friend drive around some mild hills to test it out. My body swung with the centrifugal force -- opposite the direction of turn, then swung back. It was quite relaxing. Probably illegal. Be easier to get away with it in a Panel Truck.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-13-2024 at 01:41 AM. |
