Old 07-06-2024, 11:24 AM   #1
72c20customcamper
72c20customcamper's Avatar
Inner race turns in the hub on my k20
Put it here for more exposure. Repacking the front bearings they had plenty of grease but I’m going to Tennessee next week . Bearings all clean look pristine but when wiping out the old grease the inner race turns in the hub . Not sure if I should continue or get new cups and cones
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-06-2024, 12:01 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Inner race turns in the hub on my k20
That should be a press fit. Can you slide the race out of the hub? Given the tight tolerances on bearings, I'd think that the hub is damaged.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-06-2024, 12:05 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
the race is much harder material than the hub, if it spins you need a new hub. i have in the past used a center punch to score the hub so the race would be tight- but only in an emergency situation until i could get a new hub.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-06-2024, 12:17 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Yep exactly correct. I’d replace that hub and races at a minimum asap.
Tyler
57taskforce is offline   Reply With Quote
Old 07-06-2024, 12:21 PM   #5
72c20customcamper
Looks like I’ll be taking the 72 to Tennessee.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-06-2024, 01:14 PM   #6
72c20customcamper
Ordered the complete rotor and hub assembly. Raybestos brand won’t be here till end of next week .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-07-2024, 08:50 AM   #7
72c20customcamper
Popped out the race it’s been overheated. I have the hubs coming and I just ordered the cones and cups from Rockauto
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-07-2024, 10:13 AM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Good thing you found that before you left on your trip!
~Steven
Simi Valley, CA
Old 07-07-2024, 10:17 AM   #9
57taskforce
All about them K’s
Good call, that’s probably been that way for a minute. Luckily you can still find the 44/10 bolt hubs fairly cheap/easily. It’s nice when you can get them assembled with the rotor like that. My front Dana 60 is expensive to replace hubs on and they are a little tougher to find.
Tyler
Old 07-07-2024, 11:24 AM   #10
72c20customcamper
Would have sucked big time getting stuck
Strange thing is the bearings had plenty of grease and show now sign of damage . Dust seal was in good shape so I can’t say dirt got in . The bearing and race were Bower made in USA so who knows. I bought Timkins to replace them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-08-2024, 07:21 PM   #11
72c20customcamper
Well the hubs will be here tomorrow morning I’m going to try and get the cones and cups at Napa tomorrow. The online order site says that I can order tonight and pick up tomorrow. But I’ll just go to the store early and see if I can get them . I’ve had the order now and pick up tomorrow lie before .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-08-2024, 09:54 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
If the cups in the new hub are the same brand, they should match the cones. I've seen where one can buy the cones only. I don't know if there is any savings with that, beyond the time of having to pound out the "old" ones and pound in the new ones. Working as a piece-work mechanic in the past, it would have been less labor.
~Steven
Simi Valley, CA
Old 07-09-2024, 08:48 AM   #13
72c20customcamper
It getting that way that the cone and cup is almost always sold separately. They should all be the same regardless of manufacturer say the bearing is an lm104959 if it a timkin or Bower the demensions are the same bearings are standardized throughout the industry . Didn’t even come to me the hubs may have the cups already installed
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2024, 10:03 AM   #14
Tireguy87
Locktite makes a green compound that works well for this application. I’ve had to use it for knuckle bearing races. I always knurl the edges of whatever the race is going into, apply green compound, then press the race in.
1970 GMC c15 LS swapped
1970 Chevy K20 350, 465, t221
1968 Chevy K20 400sbc, 465, t221
1968 Chevy K20 roller, to be continued…
Tireguy87 is offline   Reply With Quote
Old 07-09-2024, 11:10 AM   #15
72c20customcamper
Not a fan of chemical bonds overheat it and it turns to goo . Granted the high temp is rated to 450 degrees but I’m not trusting it . I’d rather replace than patch .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2024, 11:21 AM   #16
57taskforce
All about them K’s
Glad you are getting back together, you definitely made the right call replacing the hub. As for the newer race in the old hub I wouldn’t put it past someone in the past to have just dropped a new race into a wore out hub. Lots can happen In 35-40 years.
Tyler
Old 07-09-2024, 01:13 PM   #17
72c20customcamper
I’m the third owner . Both prior owners were very anal about the truck . I have every receipt and work invoice and every piece of the original paperwork including the bill of sale . Guy even kept the recall notices and the envelopes they came in . First owner was a mechanic second owner is a member here .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2024, 02:25 PM   #18
72c20customcamper
Hubs came today . Races were pre installed so much nicer that the rotor was installed too
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-17-2024, 05:37 PM   #19
72c20customcamper
One done
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-17-2024, 09:39 PM   #20
HO455
Post Whore
HO455's Avatar
Congratulations! Time to pour yourself a tall cool reward.
RIP Bob Parks.
Old 07-17-2024, 09:41 PM   #21
57taskforce
All about them K’s
Nice!
Tyler
Old 07-18-2024, 05:08 PM   #22
72c20customcamper
All done this morning . I think this had something to do with the shudder vibration I’ve been dealing with on the truck . Took it up to 75 mph no vibrations was super smooth
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-18-2024, 05:17 PM   #23
72c20customcamper
I had a couple seltzers (non alcoholic) gave up alcohol 4 years ago
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-20-2024, 05:25 AM   #24
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
As long as they were cold, they're still a good treat/reward!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
