Old 07-27-2024, 10:00 AM   #1
Luke87gt
Corvette 350 into C10
Hi guys,
I’ve been casually browsing local 350 engines on marketplace.
I’d like to understand what it takes to make a 350 (from a late 60s/early 70s corvette) work in my 1969 c10.
I see that the alternator is on the passenger side. Would I be able to keep the Corvette accessories as is? Also, I understand that the headers would need to change obviously. I think the radiator hoses may need to be changed.
I know that my existing clutch/TOTT would swap right over.
Is there any other major changes that I’d need to consider? Thank you.
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 07-27-2024, 02:30 PM   #2
54blackhornet
54blackhornet's Avatar
Re: Corvette 350 into C10
You will need to locate the rare Corvette/ C/10 fender call outs. Just funnin ! Most 350 stuff is interchangeable. I would find some good rams horns in place of headers myself..good luck and we like pictures…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-27-2024, 02:49 PM   #3
geezer#99
geezer#99's Avatar
Buyer beware!
Some of those corvette 350’s turn out to be 267’s.
Old 07-27-2024, 04:42 PM   #4
Lee H
Lee H's Avatar
Ask for pictures of the block casting number, the stamp pad, and the date code. Let's see what this really is.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-27-2024, 05:09 PM   #5
Luke87gt
Here it is
1969 C10 Shortbed
Old 07-27-2024, 05:52 PM   #6
Accelo
Accelo's Avatar
Originally Posted by geezer#99 View Post
Buyer beware!
Absolutely true.
I have been a Corvette owner for over 50 years. I still own the first one I purchased. I would guess 95% of the ads for Corvette motors are bogus. Owners see the same casting number and assume that makes them "Corvette". Nothing is further from the truth. Be careful out there.
In general, the short water pump Corvette motors will fit without a lot of work.
The long water pump Vette motor has issues with fan clearances and lower radiator hoses.
Cheers
Accelo is offline   Reply With Quote
Old 07-27-2024, 06:25 PM   #7
Luke87gt
Here is another shot
How can I be sure it’s a 350?
1969 C10 Shortbed
Old 07-27-2024, 06:30 PM   #8
geezer#99
geezer#99's Avatar
Get the letters and numbers off the pad in front of the passenger side head.
We’ll decode that for you.
Old 07-27-2024, 07:37 PM   #9
Luke87gt
Here is more, can anyone confirm this is 350 and from what vehicle/year?
1969 C10 Shortbed
Old 07-27-2024, 07:51 PM   #10
geezer#99
geezer#99's Avatar
Look here for engine code TJY.
https://www.nastyz28.com/gm-chevy-co...s-suffix-8.php
Old 07-27-2024, 07:51 PM   #11
chevmn
TJY suffix appears to be a 350 out of a Corvette, 1973, 1974, or 1978 with they Y signifying Corvette. I cannot recall the suffix, but I likely have a 1973 version in a Corvette with a 350.
chevmn is offline   Reply With Quote
Old 07-27-2024, 07:54 PM   #12
geezer#99
geezer#99's Avatar
It’s from a truck.
Old 07-27-2024, 07:56 PM   #13
RustyPile
RustyPile's Avatar
Yes I can.. I'm sorry to be the bearer of bad news but your engine started out life as 1973 350 cu. in. 175 HP truck engine.. The suffix "TJY" says it all..
I don't have x-ray vision, so I can't see what's inside your engine.. However, I can say that all 350 Chevy engines started out life as the same basic block.. Some of the blocks were 4 bolt main blocks and some were 2 bolt.. At some point in time, your block could have been built with "Corvette internals".
Proper de-coding can determine where the engine was built and what vehicle is to be installed. Even the day the parts were cast can be determined. Here's a link where all the numbers can be de-coded.
http://camaros.org/pdf/LimeBook.pdf
RustyPile is offline   Reply With Quote
Old 07-27-2024, 07:57 PM   #14
Luke87gt
Thanks guys, looks to be a 350 from 73-74 (or 78) according to this site:
http://www.nastyz28.com/chevy-engine-code-stampings.php
Seems ok, any reason not to pick it up to replace my tired i6?
1969 C10 Shortbed
Old 07-27-2024, 08:28 PM   #15
geezer#99
geezer#99's Avatar
Is it possible to hear it running or do a compression test?
And maybe pull the valve covers off to check head casting numbers and equal rocker movement.
It might just be a spay can rebuild.
Purty on the outside but junk inside.
What’s the price on it?
Old 07-27-2024, 08:56 PM   #16
RustyPile
RustyPile's Avatar
I'm very skeptical when it comes to buying complete engines from individuals, especially if the situation prevents me from hearing and seeing it run. I'm quite capable of building my own engines so that scenario very seldom comes up.. When I do buy a complete engine, I buy from reputable suppliers.
The following is just my opinion and YMMV.. I see lots of bling and purdy paint.. Something that even the most inexperienced person can "create" himself. Don't let all that blind you to what might be lurking beneath. The pulley system and long water pump will make it very difficult, if not impossible, to install a fan clutch and fan shroud on the radiator. The alternator is a late model that will probably require some wiring modification. The last deciding factor is price, of which you made no mention..
Old 07-27-2024, 09:19 PM   #17
Luke87gt
The engine price is $1500 (extra $200 for engine stand, Sanderson headers, and TCI starter)
Running video before it was pulled:
https://youtube.com/shorts/gENv9vY9y78?feature=shared
1969 C10 Shortbed
Old 07-27-2024, 09:57 PM   #18
RustyPile
RustyPile's Avatar
Just recently, a friend of mine bought an engine that looked outwardly like that one.. Upon disassembly, the engine was 90% junk. Crank needed machining, block was unusable, one head was cracked, plus lots of other bad stuff. It's your money to spend as you want, but again just my opinion..
If bought new, I see over $1,000 in accessories and bling. That leaves around $500 for the engine.. Like I said, don't let the shiny stuff blind you to what's underneath, a purdy paint job covers a lot of turds. Do as you wish but I'd pass..
Old 07-27-2024, 10:18 PM   #19
geezer#99
geezer#99's Avatar
Sure a bunch of extra rpm in that vid.
Turn down the idle and we might hear what’s ticking.
What’s his excuse for pulling it out?
Old 07-27-2024, 10:19 PM   #20
RichardJ
Corvettes have been in production since 1953. For the 70 years up through 2023 production they have made less than 2 million vehicles. 1,866,484 to be exact. Many of those early years, they sold less than 10,000 a year.
Between the retailers, rebuilders and private party sellers, I'd bet 20 million engines have been sold that were claimed to have been out of a Corvette.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 07-27-2024, 10:24 PM   #21
Luke87gt
He went with a big block and showed me pics with it installed
1969 C10 Shortbed
Old 07-27-2024, 11:03 PM   #22
RichardJ
[url]https://youtube.com/shorts/gENv9vY9y78?feature=shared[url]
Before it was pulled?
Picture in post #7 has different alternator and bracket, than in video? Different headers?
Old 07-27-2024, 11:07 PM   #23
RichardJ
Didn't see your big block post, but I still question
Old 07-27-2024, 11:45 PM   #24
Luke87gt
Bracket is different and he’s throwing in Sanderson headers shown below.
You guys all make good points and it’s risky to buy used. I’m gonna roll the dice here and hope for the best. If it goes south, will be a learning experience.
Will let you guys know how it goes, should have it tomorrow AM.
1969 C10 Shortbed
Old 07-28-2024, 08:06 AM   #25
chevmn
It’s from a truck.
I stand corrected. Somewhere I saw an indication that the "Y" was Corvette only, but does not appear the case, and I checked my 73 Corvette, and it does not have a Y suffix, and it is the factory engine. In any case, I do not believe that is of any real consequence in this case. I know the one in my Corvette, is a low compression, run of the mill engine.
