09-22-2024, 03:11 PM | #1 |
Active Member
Hood hinges on a 69 c10
Folks, I have found a couple of sets (used) of hood hinges that are both better than mine. I have installed both sets, and it's better but I can't get the rear of the hood to sit flush with the cowling. Are the aluminum hinges the way to go? Or is there a trick with the OEM style hinges? I have tried the full range of adjustments on the rear bolts, but still haven't got them to sit low enough to be flush.
Thanks, RonWT |
09-23-2024, 12:01 AM | #2 |
Re: Hood hinges on a 69 c10
Following
09-24-2024, 12:03 PM | #3 |
Are you able to push it down in to place after it's closed?
Mine was the same way, I could push both sides down and it would line up. I got new hinges and that fixed it.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-24-2024, 03:51 PM | #4 |
Active Member
