Old 02-06-2004, 12:31 AM   #1
racedvl
racedvl's Avatar
afb question.. . .. .
How can I test the electric choke on my 1406? Is there a spec I can check for with my dvom? If my choke is bad, can I use a choke from a conversion kit for a manual choke afb? Thanks for any help.
racedvl is offline   Reply With Quote
Old 02-06-2004, 12:39 AM   #2
jhow66
jhow66's Avatar
Just run a jumper from + post of battery to + terminal of choke--watch to see if choke blade starts to open after a few seconds--if working ok it will open all the way. Should work ok on 2nd ?.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-06-2004, 01:32 AM   #3
Hooter
My other Love
Hooter's Avatar
wouldnt that depend on the temperature though?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-06-2004, 01:53 AM   #4
jhow66
jhow66's Avatar
I was assuming the engine is cold for the test.
Old 02-06-2004, 10:13 AM   #5
racedvl
racedvl's Avatar
The problem is that I think it was draining my battery.
Old 02-06-2004, 02:00 PM   #6
jhow66
jhow66's Avatar
You must have it hooked to something that is hot all the time. Use a test light and with switch off see if you are getting power to + terimnal. If so change the source to one with power with switch on only.
Old 02-06-2004, 03:54 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Jason, if it was hooked straight to the battery, then it probably was killing it.
hook it to IGN UNFUSED
