Old 02-06-2004, 03:50 AM   #1
skippy969
floor shift conversion
I have a 1970 C10 with 3 on the tree, how difficult is it to convert it to a floor shift, its got a 250 engine, and original tranny.
EB
skippy969 is offline   Reply With Quote
Old 02-06-2004, 05:17 AM   #2
1972C10
1972C10's Avatar
Just need to get one of them three speed floor shifters
Ive got a trans out in the shop with a hurst mystery shifter its a pretty tight H pattern Reverse is at the top and to the left then first is straight down then 2nd and 2rd are to the right 2nd is up and 3rd is down
Pretty snazzy compared to the old sloppy colum shifters.
1972C10 is offline   Reply With Quote
Old 02-06-2004, 08:46 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Rebush your column shift linkage (like 5-10 bucks tops) before converting to floor. You likely won't want to convert after you're done.
Old 02-06-2004, 12:33 PM   #4
71Rat
ran out of money
71Rat's Avatar
I converted my 3 on the tree to the floor with a hurst shifter. i loved it, could shift soo much faster with it.... but then again i bent my column linkage so that didn't shift easly. I would go to the floor but thats just me. and to answer your question it is not hard at all to convert. you mount all the brackets to the transmission and then mark a spot for the shifter to come through the hall and then cut it out. just take your time and it will be easy.
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 02-06-2004, 12:39 PM   #5
mtdave2
newly minted old timer
mtdave2's Avatar
depends on what you are looking for, the floor shifters like these guys have said work well. my fav are the lokar shifters, they make one that looks exactly like the stock standard trany shifter. i fooled many people with mine, works well, and very well made.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
