Old 02-18-2004, 10:01 PM   #1
Cdn.Fleetside59
Steering Column Removal
After I have the steering wheel off of my '59 GMC Fleetside , how do I get the column itself out . All the brackets and clamps are loose or removed yet it wont break free from the steering box . Am I missing something ? Bob.
Cdn.Fleetside59 is offline   Reply With Quote
Old 02-18-2004, 10:19 PM   #2
rico_bob
"Treasure the Ride"
rico_bob's Avatar
You have to try some penetrating oil. Let it soak for a few hours then repeat the process. Sounds like the splines are rusted on.
my two cents worth. rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 02-19-2004, 10:28 PM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
After the soaking it like Rico mentions, try some wiggling and convincing.
Do not beat on it with a hammer. That could damage the steering gear and column
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-22-2004, 10:32 AM   #4
Cdn.Fleetside59
Steering Removal
In your post you mention using penetrating oil and letting it soak , question is all I have is the frame itself with the steering column , steering wheel and the cab etc is all removed . Where is it I'm supposed to place the oil in order to get the shaft free of the steering box ? Thanx , Bob.
Old 02-25-2004, 01:30 AM   #5
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Are you planning on re-using the steering box?
Old 02-25-2004, 12:10 PM   #6
greatdaen
Fleetside, I think the column tube is simply pressed into the steering gear housing. The penetrating oil should go at this joint.
-dch
greatdaen is offline   Reply With Quote
