Old 03-04-2004, 03:13 PM   #1
67chevemall
67chevemall's Avatar
Where did you buy your electric fan??
The snow finally is melting and I want to start the Chevy but I need a new electric fan!!
Who has em and which one is the best!
Thanks for any advice!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-04-2004, 03:31 PM   #2
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
the junkyard is where I am going to look, the best one is the one (or 2) that fits.
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 03-06-2004, 10:54 AM   #3
Kas68c10
Kas68c10's Avatar
Gmc Paul makes a kit specifically for our trucks, and I think Wes does too. For my little 6, I bought one from JCW for about $70 that does the job. I didnt feel like going to the junkyrd in early spring when I switched. I would go that route if I was to do it again,in the summer!
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 03-06-2004, 12:08 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Kas68c10, Thank you. We designed and make a kit for the 67-72 trucks. We give the choice of deraily or flex-a-light fans. We offer standard steel, powder coated steel, aluminum, stainless steel, and pollished stainless steel shrouds. Here is a link: http://www.classicheartbeat.com/radi...&__related.htm
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-06-2004, 12:20 PM   #5
Kas68c10
Kas68c10's Avatar
Is that good for a referrall discount Wes ?!?!? just kiddin' !
Old 03-06-2004, 01:00 PM   #6
72MARIO
72MARIO's Avatar
Will it work with a long water pump ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-06-2004, 02:28 PM   #7
bigvinnie
bigvinnie's Avatar
I bought my flex-a-lite black magic fan from summit racing, but there's a similar one being sold on ebay for considerably less that looks the same and has the same specs...
Says it's for a mustang, but it's a universal and you can make it work by fabbing your own brackets if the ones in the kit won't work....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2463941074
I just ordered one for a hemi-powered 53 Ferd stepside that my father-in-law is building, so I'll be able to report on how it compares to the more expensive flex-a-lite unit in a few days...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 03-06-2004, 02:46 PM   #8
Classic Heartbeat
Yes it works with a long water pump. The space needed between the radiator and the water pump is 4 1/2". WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 03-16-2004, 09:23 PM   #9
steve k.
Wes,
The shroud seems to block a large portion of the radiator. Will that prevent the flow at the higher speeds through the portions of the radiator that do not have a fan directly on them?
Also will this set up fit on an '81 C30 with 454?
thanks,
steve
steve k. is offline   Reply With Quote
Old 03-16-2004, 10:19 PM   #10
gr8scott51
gr8scott51's Avatar
Welcome to the board Steve. It actually improves the air flow by forming a venturi forcing air over the coils at a higher rate of flow, thereby increasing the cooling capacity of the radiator.
Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 03-17-2004, 12:16 AM   #11
whitesswj
Embrace the Redneck
whitesswj's Avatar
Wes can you mount those on the outside of the Rad? or does it have to be on the motor side of the Rad?
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-17-2004, 02:15 AM   #12
steve k.
Thanks for the welcome! I was more wondering at higher speeds when the fan is not active and the air speed comeds from the movement of the truck. The original shroud is not blocking any part of the radiator, but this one looks like it does.
steve k.
Old 03-17-2004, 02:24 AM   #13
Classic Heartbeat
The shrouds can not be mounted from the front. I just don't have it designed that way. The core support, and grill support would get in the way. gr8scott51, is correct about the better cooling. As for blocking air, it doesn't block air, because it is on the back (engine side) of the radiator. I have been running this shroud assembly on my BB Blazer for over 4 years now, and that's pulling my 5000 lb boat behind it also. I haven't even came close to running hot with them. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 03-17-2004, 02:30 AM   #14
steve k.
Thanks Wes.
Does the shroud fit an '81 Chevy c30? with a big 4 row radiator?
thanks,
steve
