Old 08-15-2024, 11:53 AM   #1
Dan-K
Turned metal dash overlay ?
Does anyone make a turned metal dash or glovebox overlay for our trucks ? I love the look on the 77-79 Trans Ams with the turned metal dash . I was thinking of attempting this myself but I would rather buy a kit if available .
Dan-K is offline   Reply With Quote
Old 08-15-2024, 02:31 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Turned metal dash overlay ?
Try here. I like that look myself, but that's a bit rich for my blood. A good price if it included the instruments.
https://www.ebay.com/itm/265021528035
~Steven
Simi Valley, CA
Old 08-15-2024, 02:47 PM   #3
54blackhornet
54blackhornet's Avatar
$500.00 ! Engine turning a piece of aluminum is a simple but tedious task. Pickup a piece and give it a try yourself.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-15-2024, 02:50 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
Thanks for the pic, I was trying to visualize something being turned on a lathe for the dash/cluster and came up blank ;-)
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 08-15-2024, 03:04 PM   #5
Shifty One
Shifty One's Avatar
It is cool, but I dunno about $500 cool....
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 08-15-2024, 03:38 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
When I was still working I had access to a machine shop. Many things were simplified.
~Steven
Simi Valley, CA
Old 08-15-2024, 04:29 PM   #7
LS short box
I think Eastwood has a "turning" kit. You supply the aluminum sheet. I haven't done it but it looks like all you need is a decent drill press.
On my 68 C10 LS swap project I got some 18 gauge sheet metal and used it to "overlay" the stock C10 bezel. I laid out the gauge pattern first and drilled all the holes. I do that first because if you do the engine turning first and when you are drilling the gauge holes and the hole saw jumps and messes up the panel you get to start over. Ask me how I know.
I used my stock gauge cluster bezel. I epoxied the 20 gauge to the stock bezel.
A pic. The center gauge is the high beam, left and right signals and check engine light. Not including the gauges I think I had maybe $20 invested.
I used all Auto Meter gauges.
Old 08-15-2024, 05:11 PM   #8
weq92f
weq92f's Avatar
Looks to me like that price does include the Dolphin gauges...
From the Ad:
Items Included
Fuel Gauge, Oil Pressure Gauge, Speedometer, Tachometer/Rev Counter, Temperature Gauge, Volt Gauge
All Gauges Feature a Convex Lens, Air Core Movements & Glare Free
1 Mechanical 5" Diameter Speedometer
1 Electric 5" Tachometer
1 Electric 2 1/16" Fuel Gauge with 0-90 ohms Adjustable Sender
1 Electric 2 1/16” Water Temp Gauge
1 Electric 2 1/16" Oil Pressure with Sender
1 Electric 2 1/16" Volt Meter
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-15-2024, 05:49 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
From the Ad:
Items Included
-Kevin
That's a smokin' deal, if Dolphin makes decent gauges!
~Steven
Simi Valley, CA
Old 08-15-2024, 07:26 PM   #10
HO455
HO455's Avatar
Make your own.
https://twistedroadcustoms.com/colle...-turned-panels
Or in cheaper plastic film.
https://www.mnpctech.com/products/en...yl-film-sheets
RIP Bob Parks.
Old 08-16-2024, 10:48 AM   #11
Dan-K
I would be happy with the stick on film but Im afraid my skill level would make it look cheesy .
Old 08-16-2024, 06:09 PM   #12
72c20customcamper
72c20customcamper's Avatar
The film has a funny look to it . Engine turnings look like half moons not circles I would try the panel but if you don’t have a drill press cutting the holes for the gages would be challenging
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-16-2024, 06:18 PM   #13
72c20customcamper
But the again if you have a drill press you could do it yourself
https://duckduckgo.com/?q=engine+tur...%3DkUj_WxtkSow
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-16-2024, 09:04 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, that film looks pretty bad, close up.
~Steven
Simi Valley, CA
Old 08-17-2024, 12:32 AM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've thought of doing this myself, but I don't have a drill press either. My GMC Jimmy came out of the St Louis plant, so I had the Spirit of Saint Louis in mind. The Ryan NYP aircraft's nose cowling had prominent ''perlage''.
If you're worried about the pilot drill for the hole saw to cut instrument holes making skip marks -- the back surface would be easier to work on.
Old 08-17-2024, 10:08 AM   #16
raggedjim
raggedjim's Avatar
There are different varieties of the film. Some look better than others.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
