Old 03-27-2026, 11:55 AM   #1
TLea
Junior Member
Factory paint sequence
Trying to get some good idea of how cab with doors was painted. I believe interior was done first. Paint break exterior/interior seems to be at weatherstrip pinchweld for jamb. The door I don't know. I see some pictures that show paint break at rear of door like the door was just closed and painted so just rear edge of door got exterior color and a lot of exterior color overspray in hinge area like you'd expect painting without fender on.
TLea is offline   Reply With Quote
Old 03-27-2026, 01:42 PM   #2
1964FarmFreshC10
Re: Factory paint sequence
https://67-72chevytrucks.com/vboard/...d.php?t=862452
1964FarmFreshC10 is online now   Reply With Quote
Old 03-27-2026, 03:49 PM   #3
TLea
Junior Member
Thank you. I saw a lot of those but still trying to figure out order, interior first or body color first. I can see what looks like fawn overspray on the body color.
Old 03-31-2026, 10:48 AM   #4
60-66
60-66's Avatar
Interior was painted first. And depending on what assembly plant built the truck along with , is it a Chevy or GMC all makes a difference . I can try and help based on what plant yours was built at with original paint trucks . I know you have a 1966 Chevrolet 292 Stepside ? If I remember correctly .
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-31-2026, 11:04 AM   #5
60-66
60-66's Avatar
My 1965 Janesville built long bed original paint
, the entire front door jamb was painted exterior color . Only if you open the door do you see the fawn interior color. Other assembly plants you see much more fawn
Old 03-31-2026, 02:00 PM   #6
TLea
Junior Member
Very helpful. Yes it’s a 66 97 inch stepside Chevrolet C20. I don’t know if I ever checked what plant it was built at how do you do that?
Old 03-31-2026, 02:10 PM   #7
Keith Seymore
Keith Seymore's Avatar
It's the 7th character from the end.
So J100001 would be a Janesville truck serial number 100001.
F = Flint
H = Fremont
A = Atlanta
S = St Louis
https://gsitlc.ext.gm.com/dealerworl...et%20Truck.pdf
etc.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old Yesterday, 10:03 AM   #8
TLea
Junior Member
OK now I'm more confused. Mine isn't even on that chart
C254 6Z112492. What am I missing?
Old Yesterday, 10:48 AM   #9
scottofksu
scottofksu's Avatar
Any chance that Z is an S?
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old Yesterday, 11:44 AM   #10
TLea
Junior Member
No its a Z
Old Yesterday, 01:27 PM   #11
Keith Seymore
The chart is for a '64 since they didn't show a '66 truck chart.
Fremont is Z for 65/66 passenger cars so I'd say Fremont build.
K
1979-1986
1986 - 2019
Old Yesterday, 01:35 PM   #12
60-66
60-66's Avatar
Definitely a Fremont Ca built truck . I'm working on one now and there's a lot of fawn showing on the front of the door jamb. Hinges are covered though.
Also I found 2 build sheets in the seat so hopefully you did as well ?
Old Yesterday, 01:40 PM   #13
TLea
Junior Member
Fremont makes sense, truck was originally delivered in CA. No luck on build sheets seat reupholstered at some point
Old Yesterday, 03:28 PM   #14
60-66
60-66's Avatar
Heres my Fremont door jamb from the inside . Original black paint truck and original interior paint. Never repainted
Old Yesterday, 03:38 PM   #15
TLea
Junior Member
Those are fantastic, thank you
Old Yesterday, 03:59 PM   #16
TLea
Junior Member
It also looks like the door stay was in place when painted. I will put those in. On the pillar side the stay was attached to the bracket with a bolt and nut, that doesn't seem correct?
Old Yesterday, 04:14 PM   #17
Grounded63
Pretty sure factory was a roll pin. At least on my 63 it was.
Grounded63 is online now   Reply With Quote
Old Today, 08:27 AM   #18
60-66
60-66's Avatar
They were definitely roll pins , not bolts .I would try to find a parts truck and take the original pins out . They are slightly flared at the top .
Old Today, 08:48 AM   #19
TLea
Junior Member
Anyone have a picture?
