10-28-2017, 07:36 PM | #1 | |
Crazy (imo) starter bolt theory. Keith we need your input
This was a question/scenario I saw posted today on the book of faces:
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
10-28-2017, 07:45 PM | #2 |
Re: Crazy (imo) starter bolt theory. Keith we need your input
No - that sounds pretty far fetched. Those are some oddly specific speculative statistics.
Additionally - small blocks and big blocks weren't made in the same place so even if a process was messed up it wouldn't affect both of those families of engines. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-28-2017, 07:47 PM | #3 |
Thanks Keith!
10-28-2017, 07:56 PM | #4 |
That also makes sense not having different engine families on the same line. I should have picked up on that as well. When I was in the machining part we did one engine series in our building, from machining to final assembly an testing. Then it went over to assembly. When they wanted to start making a 4 cyl there they built an entire new building for that....
10-29-2017, 09:06 AM | #5 |
he thanks gfor opening this topic.
It was me, that started it on FB. my small bock is driving me crazy. Tried stock starters, mini starters, high torque starters, replaced flexplate. noything works. The starter is just too far from the flexplate. video of the distance: https://youtu.be/VX_fxiU3800
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
10-29-2017, 09:45 AM | #6 |
I have this exact same issue. tried four different starters. once I determined it wasnt the starter i started shimming. i had to put two starter shims on the outer starter bolt to tilt the starter in towards the flexplate.
I have talked to alot of people about this. Some people have never used starter shims. some people have always used them. I had to use them on this engine but not the first engine in my truck nor on the engine in the 79 i used to have(that was a crate engine from who knows how long ago)
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
10-29-2017, 10:50 AM | #7 |
ill have to say I've never seen or heard of this til now...
10-29-2017, 03:20 PM | #8 |
Me either.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-29-2017, 04:08 PM | #9 |
wow, what a tall tale there..
if the removal of all shims was insufficient for the correct spacing, all nicks and dents on both mating surfaces were knocked down, the flexplate ring gear OD and tooth wear is verified in spec, and still not close enough, a small fly cut on the starter mounting surface would be my solution if I was unable to align it any other way.. good luck! Last edited by Killer Bee; 10-29-2017 at 04:28 PM. Reason: haz spelling ishews |
10-29-2017, 05:50 PM | #10 |
So at some point this engine was starting fine right? Where is the starter that was working? Never turn in your "core" until everything is back to normal.
10-29-2017, 06:10 PM | #11 |
nope, I bought it second hand, without a starter. Came from America to Europe as a spare. rebuild it. And till the day, allmost three years now, never found a starter or flexplate combo that had normal spacing. they are all to far off...close enough to start the engine, but loud as hell and will start grinding within weeks/months
10-29-2017, 10:33 PM | #12 |
Could it have been line bored excessively? I agree with Killer Bees response.
10-29-2017, 10:40 PM | #13 |
To start with, the engine in the video was using studs and nuts to hold the starter on. This is not correct! To register correctly you need to use the knurled bolts that Chevrolet used. Most parts houses can supply them. Use the correct starter for that year of block and use the bolts that match that starter. At some point GM went to metric bolts so the bolts and starter need to match. In other words metric bolts with metric starter, imperial bolts with imperial starter. The bolt shoulder should fit snugly in the block's countersunk holes and it should fit the holes in the starter snugly. If the bolts are loose in the holes in the starter, the starter can move around and will not fit the same each time it is loosened and retightened.
Get a new starter or a new nose piece, as the rebuilt ones have been remachined to clean up the surface and they will require shimming. Millions of these engines were built and operate without problems. I believe the problems start with rebuilt starters, aftermarket flywheels and people trying to reinvent the wheel. |
